Command-s use of EXPLODE not functioning
Jonathan_Bell82GXG
Message 1 of 11
Jonathan_Bell82GXG
I've got a subroutine that for the most part does what I want it to do (unioning together the green layer and unioning together the blue layer), but then I want to explode each resulting entity into its original polylines rather than the region that results from the union command. The subroutine does all this for just a single grouping (not in the sense of the GROUP command), but when I select multiple groupings it doesn't explode.
(defun c:smartTrim ( / )
  ; get ss of containing offset layers, split into 1 ss for each layer
  (setq ss (ssget '((8 . "PV Mech Equip Setback,PV Vents Skylights Roof Drains"))))
  (setq ssMech (ssdel (ssname (ssget "_L") 0) (ssget "_L")))
  (repeat (setq inc (sslength ss))
    (setq ent (entget (ssname ss (setq inc (1- inc)))))
    (if (equal (cdr (assoc '8 ent))
               "PV Mech Equip Setback"
        (progn
          (setq eName (cdr (assoc '-1 ent)))
          (ssadd eName ssMech)
          (ssdel eName ss)
  (setq ssMisc ss)
  (setq ss nil)
  ; trimming PV VENTS SKYLIGHTS ROOF DRAINS
  (command-s "_.-LAYER" "_SET" "PV Vents Skylights Roof Drains" "")
  (setq ssMiscRegion (ssdel (ssname (ssget "_L") 0) (ssget "_L")))
  (repeat (setq inc (sslength ssMisc))
    (setq ent (entget (ssname ssMisc (setq inc (1- inc)))))
    (setq eName (cdr (assoc -1 ent)))
    (command-s "_.REGION" eName "")
    (setq newEname (entlast))
    (ssadd newEname ssMiscRegion)
    (ssdel eName ssMisc)
  (setq ssMisc nil)
  (command-s "_.UNION" ssMiscRegion "")
  (setq regionToExplode (entlast))
  (command-s "_.EXPLODE" regionToExplode "") ;;; HERE - explode not working
  ; trimming PV MECH EQUIP SETBACK
  (command-s "_.-LAYER" "_SET" "PV Mech Equip Setback" "")
  (setq ssMechRegion (ssdel (ssname (ssget "_L") 0) (ssget "_L")))
  (repeat (setq inc (sslength ssMech))
    (setq ent (entget (ssname ssMech (setq inc (1- inc)))))
    (ssadd newEname ssMechRegion)
    (ssdel eName ssMech)
  (setq ssMech nil)
  (command-s "_.UNION" ssMechRegion "")
  ; exit quietly
  (princ)
Any suggestions?
Replies (10)
Message 2 of 11
ВeekeeCZ
perhaps add (initcommandversion) predecessor
        (progn
          (ssdel eName ss)
  (setq ssMisc ss)
  (setq ss nil)
  (setq ssMisc nil)
  (setq ssMech nil)
  ; exit quietly
  (princ)
Message 3 of 11
ВeekeeCZ
BTW this construct is ridiculous
just use
(setq ssMech (ssadd))
it creates an empty selection set.
Also, in general, I would rather use simple (command) instead of (command-s)...
Message 4 of 11
Jonathan_Bell82GXG
Thanks for the input on making empty selection sets haha. Isn't command-s faster than command though? What are the downsides of command-s aside from less flexibility in how you use the command function?
Message 5 of 11
Jonathan_Bell82GXG
(initcommandversion) didn't change anything-- still doesn't explode entities in the second case
Message 6 of 11
ronjonp
When in doubt remove command calls:
(vla-explode (vlax-ename->vla-object regiontoexplode))
(entdel regiontoexplode)
Message 7 of 11
Jonathan_Bell82GXG
Still nothing. Is there something about REGIONs that make this more difficult?
Message 8 of 11
ronjonp
No ... do you read the Autodesk documentation? HERE.
Message 9 of 11
ВeekeeCZ
Yes. You need to explore how those commands work. Mainly whether creates a new entity or just changes the original. Use (entsel) for that. UNION does not create a new entity!
Also, EXPLODE is tricky when comes to regions. It creates a polyline only if it is one object. Else create regions.
Your routine fixed.
(defun c:smartTrim ( / ss )
    (setq ent (ssname ss (setq inc (1- inc))))
    (if (= (cdr (assoc 8 (entget ent))) "PV Mech Equip Setback")
      (progn
	(ssadd ent ssMech)
	(ssdel ent ss))))
  (setq ssMisc ss)
  (command-s "_.-LAYER" "_Make" "PV Vents Skylights Roof Drains" "")
  (setq ssMiscRegion (ssadd))
  (setq ssMisc nil)
  (command "_.EXPLODE" "_p" "") ;;; HERE - explode not working
  (command "_.JOIN" "_p" "")
  (setq ssMech nil)
  (command-s "_.EXPLODE" "_p" "")
  ; exit quietly
  (princ)
But it would be much faster, if you supply REGION with a selection set (all at once), like this.
(defun c:SmartTrim ( / *error* s i e y l N)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if lay (setvar 'clayer lay))
    (if del (setvar 'delobj del))
    (princ))
  (setq lay (getvar 'clayer))
  (setq del (getvar 'delobj)) ; ?? set to what
  (if (setq s (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (0 . "CIRCLE") (-4 . "OR>"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    y (cdr (assoc 8 (entget e)))
	    l (if (setq a (assoc y l))
		(subst (cons y (ssadd e (cdr a))) a l)
		(cons  (cons y (ssadd e)) l)))))
  (foreach i l
    (setq e (entlast) n (ssadd))
    (setvar 'clayer (car i))
    (command "_.region" (cdr i) "")
    (while (setq e (entnext e)) (ssadd e n))
    (command "_.union" n "")
    (command "_.explode" "_p" "")
    (command "_.join" "_p" "")
    (if (setq n (ssget "_p" '((0 . "REGION"))))
      (command "_.erase" n ""))
  (*error* "end")
Message 10 of 11
ВeekeeCZ
Not sure about that. Why do you think so?
The main issue (or advantage it you know what are you doing) is that command-s does not leave the command if an error occurs and then continues in evaluation of the following code (this could be very risky).
The command stops evaluation and goes straight to the *error* function.
Message 11 of 11
Kent1Cooper
....  What are the downsides of command-s aside from less flexibility in how you use the command function?
Read about the differences between the two in >Help for the (command-s) function<.
Kent Cooper, AIA
