Code help for turning on layers
Hello All,
I'm new to writing code and can't seem to get this one figured out. I want to activate the command, be prompted for a word, then have every layer with that word turn on. (such as "contour" then all of my countour layers turn on.)
Here's the code and thanks again in advance for any help you can give me.
Jason
(DEFUN C:RF ()
  (setq wild(getstring "\nEnter part of layer name: ")) ;Gets the layer name
  (command "-layer" "_on" (concatenate 'string "*" wild "*"))
  (command "-layer" "_thaw" (concatenate 'string "*" wild "*"))
  (command "regen")
(princ)
paullimapa
AutoLISP does not have a  concatenate  function but does have a  strcat  function.  So change the code to this and it should work:
(DEFUN C:RF ()
  (command "_.Layer" "_On" (strcat "*" wild "*") "_Thaw" (strcat "*" wild "*") "")
  (command "_.Regen")
  (setq wild nil)
  (princ)
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
Works perfect. I knew that was the problem, but didn't know the right command.  Thanks!
paullimapa
