CHANGE SIZE OF THE EDIT ATTRIBUTES BOX
htls69
Message 1 of 8
htls69
i was wondering if there is anyway to change the number of lines that are shown in the edit attributes dialog box i dont want to use the next box i want to do it all by keyboard
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
Replies (7)
Message 2 of 8
paullimapa
Is there a reason why you don't want to use the Enhance Attribute Editor   Eattedit     command which does allow you to stretch the dialog and show more attributes?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 8
htls69
it is a lot easier and faster to use that dialog bog of the block that we
use for the border
Allen G. Robberson Jr.
about.me/allenrobberson
I use @hover to register my domains and I think you should too! Try them
out: https://hover.com/3g1yWJrV #hoverlove
Allen Robberson
Message 4 of 8
paullimapa
Actually I've not seen the standard ATTEDIT have the Dots button to click on next to the value entries.  Are you using a custom Attribute Edit command?
Paul Li
IT Specialist
@The Office
Message 5 of 8
htls69
USING ATTEDIT IT LOAD SO MUCH FASTER THAN THE OTHER WAY
Allen Robberson
Message 6 of 8
htls69
THE DOTS ARE FOR EDITING MULTILINE TEXT
Allen Robberson
Message 7 of 8
paullimapa
I see...I've just never had any attributes with mulitple lines before so I've not seen those dots button.
Not sure why ATTEDIT would load faster than EATTEDIT.  It's the same speed for me on my system.
With the EATTEDIT window, I just have to use a few more keystrokes (SHIFT+TAB then Arrow Down) to jump to the next entry.
Paul Li
IT Specialist
@The Office
Message 8 of 8
htls69
IN THE OTHER ONE ALL I HAVE TO DO IS TAB TO THE NEXT BOX
Allen Robberson
