How to determine if block is dynamic?
mid-awe
Message 1 of 17
mid-awe
Hi all,
Is there a simple process to determine if a block is dynamic?
I need to use the block name and there will only ever be just one in the drawing at a time. An obsolete version of the block has no attributes or anything, while the updated version has two visibility states. I need to detect if the block is dynamic, and if not, I need to redefine the block with the new version.
I had set up a lisp that would simply redefine the block in every drawing but for a reason I could not understand, it would fail sometimes.
Also, this is my code for testing, but I keep getting an error:
(IF (= (VLA-GET-ISDYNAMICBLOCK (VLAX-ENAME->VLA-OBJECT (TBLOBJNAME "block" BLKNM))) :VLAX-FALSE)
    (SETQ MSG "NO")
    (SETQ MSG "YES")
The error I get is:
error: ActiveX Server returned the error: unknown name: IsDynamicBlock
Please help. Thank you.
Replies (16)
Message 2 of 17
hmsilva
EDIT:
blknm as a valid blockname
(= (vlax-get (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blknm) 'IsDynamicBlock) -1)
Henrique
Message 3 of 17
mid-awe
No problem; I'm still digging for clues. Thank you.
Message 4 of 17
hmsilva
HI mid-awe,
I did edit my previous reply.
Henrique
Message 5 of 17
mid-awe
Thank you =D That did the trick.
(Apparently, I just responded before you made your edit. As soon as I posted, there was your edit. Thank you.)
Message 6 of 17
mid-awe
I was away looking for other solution, thank you again.
Message 7 of 17
hmsilva
You're welcome, mid-awe!
Glad I could help
Henrique
Message 8 of 17
mid-awe
Henrique, Thank you very much.
Can you share any insight into the error? What is the cause, and how does your version avoid it?
I use your code to determine if the block is dynamic, and then if it is I call a sub-function to change the visibility state. The sub-function is now throwing the error, and it worked before. I'm hoping to understand what about my code is not finding the "IsDynamicBlock". Do I need to release the object before calling the subfunction?
Any help is greatly appreciated. Thank you.
Message 9 of 17
hmsilva
Hi mid-awe,
Using 'TBLOBJNAME' function to get the block ename, and using it as argument to the 'VLAX-ENAME->VLA-OBJECT' function, and dump the object proreties and the supported methods:
_$ (vlax-dump-object (VLAX-ENAME->VLA-OBJECT (TBLOBJNAME "block" "BlockName")) T)
; IAcadEntity2: AutoCAD Entity Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00000001406ea1d8>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000003c25d860>
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "23A"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000003fe159f8>
;   Layer = "0"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   ObjectID (RO) = 42
;   ObjectID32 (RO) = 42
;   ObjectName (RO) = "AcDbBlockBegin"
;   OwnerID (RO) = 43
;   OwnerID32 (RO) = 43
;   PlotStyleName = "ByLayer"
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000003fe15a50>
;   Visible = -1
; Methods supported:
;   ArrayPolar (3)
;   Update ()
T
_$
we don't have the 'IsDynamicBlock' property avaliable...
We need to use the block from the block collection from the active document to acess to the 'IsDynamicBlock' property and others...
_$ (vlax-dump-object (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) "BlockName") T)
; IAcadBlock: A block definition containing a name and a set of objects
; Property values:
;   BlockScaling = 1
;   Comments = ""
;   Count (RO) = 12
;   Explodable = -1
;   Handle (RO) = "217"
;   HasExtensionDictionary (RO) = -1
;   IsDynamicBlock (RO) = -1
;   IsLayout (RO) = 0
;   IsXRef (RO) = 0
;   Layout (RO) = AutoCAD.Application: The property is not available in current state
;   Name = "BlockName"
;   ObjectID (RO) = 43
;   ObjectID32 (RO) = 43
;   ObjectName (RO) = "AcDbBlockTableRecord"
;   Origin = (0.0 0.0 0.0)
;   OwnerID (RO) = 44
;   OwnerID32 (RO) = 44
;   Path = AutoCAD.Application: Not applicable
;   Units = 4
;   XRefDatabase (RO) = AutoCAD.Application: No database
;   Add3DFace (4)
;   Unload ()
T
_$
'The sub-function is now throwing the error, and it worked before.'
It should not, post the sub-function and the code lines where you are setting variables and call the sub-function (if possible)
Henrique
Message 10 of 17
mid-awe
Ok, that certainly makes things clearer. Below is the info you asked for:
(DEFUN CHGVIS (E NEWVAL / OBJ SAL PROPNAME PRP)
  (SETQ	OBJ	 (IF (= (TYPE E) 'VLA-OBJECT) E (VLAX-ENAME->VLA-OBJECT E))
	PROPNAME "Visibility"
  (IF (= (VLAX-GET-PROPERTY OBJ 'IsDynamicBlock) :VLAX-TRUE)
    (PROGN
      (SETQ SAL	(VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLA-GETDYNAMICBLOCKPROPERTIES OBJ)))
	    PRP	(VL-REMOVE-IF-NOT (FUNCTION (LAMBDA (X) (= (VLAX-GET-PROPERTY X 'PROPERTYNAME) PROPNAME))) SAL)
      (MAPCAR (FUNCTION	(LAMBDA	(V) (IF (VLAX-PROPERTY-AVAILABLE-P V 'VALUE) (PROGN (VLAX-PUT-PROPERTY V 'VALUE NEWVAL) (VLA-UPDATE OBJ))))) PRP)
(DEFUN ORDER (/ BLK ENM)
  (VL-LOAD-COM)
  (SETQ	BLK "ORDERBOX"
	ENM (TBLOBJNAME "block" BLK)
  (IF (TBLSEARCH "block" "ORDERBOX")
    (IF	(= (VLAX-GET (VLA-ITEM (VLA-GET-BLOCKS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT))) BLK) 'ISDYNAMICBLOCK) -1)
      (CHGVIS ENM "YES")
      (PROGN
	(COMMAND "._-insert" (STRCAT BLK "=") (COMMAND))
	(ORDER)
    (PRINC (STRCAT "\n\t !>>" BLK " is not found in current drawing <<!\n"))
I believe you have possibly provided the best clue, but I don't want to make the change to the sub-function until I'm certain.
Thank you again Henrique.
Message 11 of 17
hmsilva
mid-awe,
I'm getting confused...
Is your goal, to  change the block definition  visibility state?
Or change the insert visibility state?
Henrique
Message 12 of 17
mid-awe
Sorry for the confusion.
This particular block is part of a template; no need to insert. For backwards compatibility with old drawings, I redefine the old block with the dynamic version before changing the visibility state. It seemed like a good Idea to utilize the same tools for old version and new.
I hope that is more clear.
Thank you again.
Message 13 of 17
hmsilva
mid-awe,
your CHGVIS function acepts as argument a ename or a vlaobject, and is testing for DynaProps...
At ORDER function, you have
(CHGVIS ENM "YES");<<<<< ENM is the 'Block  Definition', and will throw an error in the CHGVIS function when testing for DynaProps...
Probably, just test for Dynamic Props, in the existing 'Block  Definition', and if not dynamic, insert/redefine the block, will suffice.
Henrique
Message 14 of 17
mid-awe
Thank you again. Everything is working as expected. =D
Message 15 of 17
hmsilva
You're welcome,
Glad you have it sorted!
Another way to test the block definition for dynamic properties, might be something like this:
(defun is_dyn (blkname / )
  (if (assoc 360 (entget (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" blkname)))))))))
    T
Hope this helps,
Henrique
Message 16 of 17
Above LSP variant doesn't work.
Alternate solution:
(defun IsDynBlockDefinition (blkname / )
(member '(3 . "ACAD_ENHANCEDBLOCK") (entget (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" blkname)))))))))
Message 17 of 17
mid-awe
I'll give it a try.
Thank you.
