Erase within coordinates
Message 1 of 14
Can anyone help me with this lisp?
It's supposed to erase text objects within an imaginary rectancle, coordinates 15,35 to 295,40 by window type select so only the text objects fully enclosed within the rectangle get erased.
The lisp I'm trying to create fails on the second line in Vlide but I cannot see the error(s)
- Simon
(defun C:DTTX (/ ss1)
  (if (setq ss1 (ssget '(15 35) '(295 40) '((0 . "TEXT")))
    (command "_.erase" ss1 "")
    (alert "TEXT Not Found")
  (princ)
Replies (13)
Message 2 of 14
ВeekeeCZ
See this Lee Mac's cool page
http://www.lee-mac.com/ssget.html
...with this example...
(ssget "_C" '(0 0) '(2 1) '((0 . "CIRCLE")))
Edit:
Spoiler
Spoiler
(if (setq ss1 (ssget "_C" '(15 35) '(295 40) '((0 . "TEXT")))) ;watch parenthesis
(princ)
Message 3 of 14
Hi BeekeeCZ. That's where I got the idea from!
Thanks anyway
Message 4 of 14
Kent1Cooper
Or, if you want the Window-type rather than the Crossing-type selection:
  (if (setq ss1 (ssget "_W" '(15 35) '(295 40) '((0 . "TEXT")))
If you give (ssget) two points without the "_C" or "_W" designation, it only picks at the two points, and will find anything that may be located at them, but if not, it doesn't automatically go into Window/Crossing mode, as it does when you do this manually.  So you need to specify that.
Kent Cooper, AIA
Message 5 of 14
Hello Kent
Unfortunately it still doesn't work, it say's 'error: syntax error'
It's driving me nuts
  (if (setq ss1 (ssget "_W" '(15 35) '(295 40) '(0 . "TEXT"))))
  );; End of if
  (princ)
Message 6 of 14
ВeekeeCZ
Watch parentheses...
(if (setq ss1 (ssget "_W" '(15 35) '(295 40) '((0 . "TEXT"))))
);; End of if
(princ)
Message 7 of 14
Thank you BeekeeCZ
Works a treat. Thank you too Kent
Stoopid brackets !
Message 8 of 14
ВeekeeCZ
That's all about them...
In Visual LISP editor (command VLIDE from AutoCAD) you have some tools to better control of them.
If you type closing ) you get a visual cursor control with the pair bracket.
Then try:
CTRL + [
CTRL + ]
SHIFT + CTRL + [
SHIFT + CTRL + ]
More of them:
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-CAD3B7DA-0295-4ABE-91A4-AA7617BA263C
Message 9 of 14
I didn't know that, very useful & quite easy too. Thank you
Message 10 of 14
Can someone please explain what '((0 . "TEXT")) does? I have been trying to use this LISP to delete everything contained within a rectangular coordinate system (1075874.0,-700742.0, 1075874.0,-262165.0, 1288360.0,-262165.0, 1288360.0,-700742.0) but nothing is removed. I have no idea what I am doing wrong.
Any help is greatly appreciated.
Message 11 of 14
ВeekeeCZ
It keeps only TEXT entities within the selection.
So if you want to select everything, remove that.
Message 12 of 14
it appears, or at least by dumb luck I discovered, that I needed to add
(command "_.ZOOM" "_E")
before the code as I assume it requires everything to be visible before it functions properly.
Message 13 of 14
Kent1Cooper
It shouldn't require everything to be visible -- only everything selected  by the routine.  You could just Zoom using the coordinates of the window you want things selected in, rather than to the Extents.  It would reduce the likelihood of a Regeneration being required, as well as presumably most of the time letting you see what's happening at larger screen size.
Kent Cooper, AIA
Message 14 of 14
AH! I will change my zoom from extents to window of the coordinates of the selection area. Thanks @Kent1Cooper! You guys are so helpful on here
