Insert Object in Block - Lisp
I create a copy of object: (SETQ OBJ-BIM (VLA-COPY OBJ-BAR)) And create a insert block: (SETQ BLOCK-OBJ (VLA-ADD (VLA-GET-BLOCKS doc) PT BLOCK-NAME-STR)) How i insert my object copy "OBJ-BIM" in my "BLOCK-OBJ". Help, thanks!
paullimapa
Seems like a few things missing in your code like what are these:
doc
PT
BLOCK-NAME-STR
Also when did you incorporate OBJ-BIM as part of block BLOCK-OBJ?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
My doubt is how to insert an object existing in a block also existing.
