Changing Layer Status and saving part of the drawings as DXF format
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone
At the moment we are using this workflow as some part of daily usage.
I would like to improve and automate as much as possible.
The sequence is as follows.
We work with 40 layers. Most of them are measurements and such things.
We export the Layouts as PDF.
We change predefined Layerstatus and only enable 8 layers for the CNC.
We manually select the necessary part of the drawing and write it as Block (WBLOCK) as DXF2000 and R12 separately on 2 different folders on the server.
If possible i would like to optimize this layerstatus change, selection, naming, and saving this 2 times in 2 different folders with 2 different formats.
Would it be possible to achieve such a task?
For example,
File name 45001_002_ko.dwg
Drawings saved as PDF 45001_002.pdf in PDF Folder
We made selection and identical drawing saved as 2 different formats under 2 different orders
45001002.dxf (R12) in R12 folder
45001002.dxf (2000) in 2000 folder
Thank you. Best Regards
Kadir (AutoCAD 2024 LT)
