Help understanding global variables vs local variables
Alex_Hughes6GQ7S
Alex_Hughes6GQ7S
Hello, and thanks in advance for reading this. I'm a CAD drafter teaching himself a little AutoLISP between projects at work. I don't have any real coding experience prior to this, and am learning mostly by searching through documentation and using the blessed AfraLISP guides. I have already done some searching through these forums as well. Specifically, this link back from 2018 didn't do much to help me, and only served to confuse me more.
I'm having some trouble understanding the difference between global and local variables. I thought a variable being global meant that if it was changed in a function call, it would stay changed if used again outside that function. And a local variable would be discarded after that function call was finished.
I've got some code to explain my problem:
(defun testMe ()
  (setq l1 (list 1 2)
        l2 (list 2 3)
  (princ l2)
  (defun addPoints (l1 l2)
    ;Adds the values of two points together
    ;l1 = first point
    ;l2 = second point
    (setq a (+ (car l1) (car l2))
          b (+ (cadr l1) (cadr l2))
          l2 (list a b)
  (princ (addPoints l1 l2))
  (princ l2)
  (princ)
addPoints just takes two points, and adds them together. To my understanding, l1 and l2 are global here (not defined following a / ). At the end of the addPoints function, l2 is set to the sum of the two points. Line 19 prints this to verify it.
Because l2 is global, I would expect the value it is set inside of the addPoints function to be retained even after the addPoints function has ended. So after running (testMe), I should receive an output of (l2 prior to call)(l2 after call)(l2 after call), or (2 3)(3 5)(3 5).
What I'm actually getting is (2 3)(3 5)(2 3). I can see that while l2 is being successfully called during the addPoints function, the value isn't being saved afterwards, despite the addPoints function passing the value to the (princ) command. This is how I'd expect the code to run if I had defined it as (addPoints ( / l1 l2)) So, I think I'm missing something about how global vs local variables work.
I don't want to be rude or presumptuous, but I'd prefer responses that directly address my misunderstanding here, as opposed to asking why I didn't do this in a different way or offering another method (unless what I'm thinking is just completely wrong, of course). In this exact example, I'm sure there are plenty of workarounds and other ways to do this, but I'd like to be able to use functions to redefine more complicated items (like drawing elements) in the future, and being able to call (modifyElement(element value)) instead of having to step around with repeated (assoc)'s and (subst)'s would make my life a lot easier, and my code more readable.
Thanks again for your time!
ВeekeeCZ
See THIS first.
l1 and l2 are arguments! And from the link above:
The symbols used as arguments are defined in the argument list before the local variables. Arguments are treated as a special type of local variable; argument variables are not available outside the function. You cannot define a function with multiple arguments of the same name.
Alex_Hughes6GQ7S
So if I wanted to change the start point of a line entity, I can't do something like this:
(defun moveLineStart (line destination)
  ;line = line to move
  ;destination = desired new coordinates of line start point
  (subst
    (cons (car destination) (cadr destination))
    (assoc 10 line)
    line
(I know entities aren't this easy to modify, but I think you understand what I'm trying to do here)
Instead I'd have to use the substitute chunk of code every time? That works, but it just adds a lot more text to the code, and I like to keep my code as short and easy to parse as I can
Kent1Cooper
The start point entry in entity data needs to start with a 10, but you can tack that right onto the front, without splitting the destination coordinates into separate entries.  And you then need to modify that entity to have its substituted entity data list take effect:
  ;line = entity data list of line to move [not just entity name]
  (entmod
    (subst
      (cons 10 destination)
      (assoc 10 line)
      line
    ); subst
  ); entmod
Kent Cooper, AIA
johnyDFFXO
Sure you can. But for the arguments, I would prefer to use different names than the original variables.
(defun moveLineStart (ent pnt / def)
  ;ent = line to move
  ;pnt  = desired new coordinates of line start point
  (setq def (entget ent))
  (entmod (subst (cons 10 pnt)
		 (assoc 10 def)
		 def))
  ent ; make sure it returns ename
Or more typically:
(defun MainProgram ( / _moveLineStart _moveLineEnd)
  (defun _moveLineStart (d p)
    (subst (cons 10 p)   ;; subst returns definition
	   (assoc 10 d)
	   d))
  (defun _moveLineEnd (d p)
    (subst (cons 11 p)    ;; subst returns definition
	   (assoc 11 d)
	   d))
  (if (setq ent (car (entsel "\nSel the line: ")))
    (while (and
	     (setq pt1 (getpoint "\nNew beginning: "))
	     (setq pt2 (getpoint "\nNew end: "))
      (progn
	(setq def (_moveLineStart def pt1)) ; save the return of your sub
	(setq def (_moveLineEnd   def pt2))
	(entmod def)
Kent1Cooper
@Alex_Hughes6GQ7S wrote:
.... I'd have to use the substitute chunk of code every time? ... it just adds a lot more text to the code, and I like to keep my code as short and easy to parse as I can
For that, consider alternative ways to achieve the same thing that may be available.  For example, in this case, if line is an entity name, not an entity data list:
  ;line = line entity name [not entity data list] to move
  (setpropertyvalue line "StartPoint" destination)
Kent Cooper, AIA
Sea-Haven
A couple of suggestions.
(setq pt3  (mapcar '+ pt1 pt2) )  ;  adds 2 points
(setq pt3 (mapcar '(lambda (x) (/ x 2.0)) pt3)  ;   divide by 2
(setq mp (mapcar '* (mapcar '+ p1 p3) '(0.5 0.5))) ; add & divide
You only need 1 function not 2 for lengthen, if you select the entity near an end can check which end you picked so for your task lengthen that end. An example.
(defun swapends (ent / obj)
(setq pt3 (cadr ent))
(setq obj (vlax-ename->vla-object (car ent)))
(setq start (vlax-curve-getstartPoint obj))
(setq end (vlax-curve-getEndPoint obj))
(setq d1 (distance pt3 end))
(setq d2 (distance pt3 start))
(if (< d1 d2)
(progn
(setq temp end)
(setq end start)
(setq start temp)
(princ)
