Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Can use vlisp write a routine ? thanks
Message 1 of 9
when drawing "line" ,can Enter "A" to  "select the target line" , specify a angle .
"You can if you want to make a line PARallel to an existing line, or PERPendicular to an existing line."
I know ,can input Keyword “per” and "par" to do this ,bat can't specify a angle ! I think vlisp can do this , someone can write a routine ?
Replies (8)
Message 2 of 9
Kent1Cooper
I'm not sure I understand exactly what you're asking, but assuming some things:
If you want to draw a Line at a specified angle, and you know how long you want it to be, use the relative-displacement @length<angle approach:
Specify next point or [Undo]: @123.456<45
If you don't know the length but want to drag the length dynamically on-screen, and want it to be locked into a specified angle, you can use the < to specify that angle:
Specify next point or [Undo]: <45
and drag the length with the cursor.  The Line direction will be locked into the 45-degree [or the opposite 225-degree] direction, in the same way as it's locked into the four quadrant directions when Ortho is on.  [Such an angle designation will override Ortho.]
You can also specify the angle in that way, drag the cursor in the right direction, and then type in a length value, which is another way to do it when you know the length.
Kent Cooper, AIA
Message 3 of 9
Thanks ,kent1cooper, thank you for reply ,but That's not what I mean.
I know how to draw a line with angle (@length<angle ).
I mean :
when drawing line , can pick  another line(target line)  , Enter the angle ,This angle  between the line and the reference line . if Enter the angel  is: 0 ,so this line PARallel the target line ,  if Enter the angle is : 90  , so this line PERPendicular the target line.   Of course also can enter the other Angle.
Message 4 of 9
Kent1Cooper
@Anonymous wrote:
when drawing line , can pick  another line(target line)  , Enter the angle ,This angle  between the line and the reference line .....
Isn't that exactly what your video demonstration of a "ZWMIntelligentLine" command shows?  If so, what need is there for another routine?  If not, how does what you want to do differ from what is shown in the video?
Kent Cooper, AIA
Message 5 of 9
Hi Mr. kent
I need this routine as "ZWMIntelligentLine" , This CAD is not Autocad , only a Trial software. Thanks !
Message 6 of 9
marko_ribar
Maybe something like this :
(defun c:alin ( / *adoc* pt opt ptt esel ent pent ang difang nang ptw )
  (vl-load-com)
  (setq *adoc* (vla-get-activedocument (vlax-get-acad-object)))
  (setq pt (getpoint "\nSpecify first point : "))
  (while
    (and
      (setq opt (cons pt opt))
      (not (initget 128))
      (setq ptt (getpoint pt "\nSpecify next point or - F8 for orthomode [Angle line/Undo] : "))
      (setq opt (cons ptt opt))
    (cond
      ( (eq (type ptt) 'list)
        (vla-startundomark *adoc*)
        (command "_.LINE" "_non" pt "_non" ptt "")
        (setvar 'orthomode 0)
        (setq pt ptt)
        (vla-endundomark *adoc*)
      ( (or (wcmatch ptt "a*") (wcmatch ptt "A*"))
        (setq esel (entsel "\nPick target curve to obtain its angle"))
        (setq ent (car esel))
        (setq pent (vlax-curve-getclosestpointto ent (cadr esel)))
        (setq ang (angle '(0.0 0.0) (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent pent))))
        (setq difang (cvunit (getreal "\nSpecify angle to picked curve in decimal degrees : ") "degree" "radian"))
        (setq nang (cvunit (- ang difang) "radian" "degree"))
        (setq ptw (trans pt 1 0))
        (command "_.UCS" "_W")
        (command "_.UCS" "_Z" nang)
        (setvar 'orthomode 1)
        (command "_.LINE" "_non" (trans ptw 0 1) "\\")
        (while (> (getvar 'cmdactive) 0) (command ""))
        (setq ptw (trans (getvar 'lastpoint) 1 0))
        (command "_.UCS" "_P")
        (setq pt (trans ptw 0 1))
      ( (or (wcmatch ptt "u*") (wcmatch ptt "U*"))
        (command "_.UNDO" "")
        (if (eq (length opt) 2) (setq pt (cadr opt)) (progn (if (equal (cadr opt) (cadddr opt) 1e-8) (setq opt (cddddr opt)) (setq opt (cddr opt))) (setq pt (cadr opt))))
  (princ)
 HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 7 of 9
marko_ribar
Update, now it creates LWPOLYLINE... If you want only lines, just explode upon routine execution... And my previous code had some lacks, I suggest that you use this new one...
(defun c:alin ( / *adoc* pea pt opt ptt el esel ent pent ang difang nang ptw ss )
  (vl-load-com)
  (while
    (and
      pt
      (not (initget 128))
    (cond
        (setq el (cons (entlast) el))
        (setq pt ptt)
          (setq pt nil)
          (progn
            (if (null opt)
              (setq pt nil)
              (progn
                (setq el (cdr el))
  (if (not (null el))
    (progn
      (setq ss (ssadd))
      (foreach l el
        (ssadd l ss)
      (setq pea (getvar 'peditaccept))
      (setvar 'peditaccept 1)
      (command "_.PEDIT" "_M" ss "" "_J")
      (setvar 'peditaccept pea)
  (princ)
 HTH, M.R.
Message 8 of 9
marko_ribar
One more remark...
Look here :
http://www.cadtutor.net/forum/showthread.php?90298-smart-line/page4&p=#35
M.R.
Message 9 of 9
Very very very thank you ! Marko .I'm very honored and grateful!!  Best wishes for a wonderful new year!
