figuring out SUBSTR codes
Message 1 of 1
Good morning all.
I'm working on someone else's code (they no longer work here) and trying to figure out what he has done with a SUBSTR code to filter out certain text.
I've spent way too much time trying to figure this out and could really use a good eye to help me learn what is going on.
the code:
takes text from an attribute, strips certain key words and assigns a weight to it.  EG. looks for a size of 1" and gives it a weight of 10 kgs.
the problem:
the text order has changed a bit and now the code does not work 100%.  it no longer recognizes 1/2" increments.  IE. it will recognize 1-1/2" but not 1 1/2".  it thinks 1 1/2" is actually 1/2" and assigns the 1/2" weight to it.
the NEW text would read something like this:
%%c2 1/2" x 20' (%%c64mm x 7.6m) SLING
the OLD text would read:
20' x 2 1/2"%%c (7.6m x 64mm%%c) SLING
I've stripped the code down, as its quite long, and added some notes.  as well uploaded a dwg of the blocks we are using.
if anyone could help me decipher whats going on it would be much appreciated.
thankyou
Replies (0)
