Calculate area in Meter Square
Message 1 of 14
This lisp is used to Calculate the area of an object in square feet.
1. Please Edit it to calculate in Square meter.
2. Please Edit it to calculate for multiple objects.
;;; AreaText.LSP ver 3.0 ;;; Command name is AT ;;; Select a polyline and where to place the text ;;; Sample result: 2888.89 SQ. FT. ;;; As this is a FIELD it is updated based on the FIELDEVAL ;;; or the settings found in the OPTIONS dialog box ;;; By Jimmy Bergmark ;;; Copyright (C) 2007-2010 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; 2007-09-05 - First release ;;; 2009-08-02 - Updated to work in both modelspace and paperspace ;;; 2010-10-29 - Updated to work also on 64-bit AutoCAD ;;; Uses TEXTSIZE for the text height (defun Get-ObjectIDx64 (obj / util) (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)))) (if (= (type obj) 'ENAME)(setq obj (vlax-ename->vla-object obj))) (if (= (type obj) 'VLA-OBJECT) (if (> (vl-string-search "x64" (getvar "platform")) 0) (vlax-invoke-method util "GetObjectIdString" obj :vlax-False) (rtos (vla-get-objectid obj) 2 0) ) ) ) (defun c:AT (/ entObject entObjectID InsertionPoint ad) (vl-load-com) (setq entObject (vlax-ename->vla-object(car (entsel))) entObjectID (Get-ObjectIDx64 entObject) InsertionPoint (vlax-3D-Point (getpoint "Select point: ")) ad (vla-get-ActiveDocument (vlax-get-acad-object)) ) (vla-addMText (if (= 1 (vla-get-activespace ad)) (vla-get-modelspace ad) (if (= (vla-get-mspace ad) :vlax-true) (vla-get-modelspace ad) (vla-get-paperspace ad) ) ) InsertionPoint 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " entObjectID ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%" )) )
Replies (13)
Message 2 of 14
ВeekeeCZ
You can try this one... from my archive..
Spoiler
(defun c:PLArea  (/ acsp ss e ptList ID StrField txt p)
  (vl-load-com)
  (command "_.undo" "_be")
  (setq  acsp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
  (if (setq ss (ssget ;(progn
			;(initget 1 "Y N")
                        ;(setq ans (getkword "\nProcess All Polylines [Yes/No]: "))
			;(if (eq "Y" ans)
			  ;"_X"
			  ":L";))
		      '((0 . "*POLYLINE")
                        ;(8 . "A-AREA-BDRY")
                        (-4 . "&")
                        (70 . 1)(410 . "Model"))))
    (repeat (sslength ss)
            (setq e     (ssname ss 0)
                  sum   '(0 0)
                  verts (cdr (assoc 90 (entget e))))
            (setq ptList
                       (mapcar 'cdr
                               (vl-remove-if-not
                                     '(lambda (x) (= (car x) 10))
                                     (entget e))))
            (foreach x ptList (setq sum (mapcar '+ x sum)))
            (setq ID (itoa (vla-get-objectid (vlax-ename->vla-object e))))
            (setq StrField
			       ID
			       ">%).Area \\f \"%lu2\">%"))
            (vla-put-AttachmentPoint
                  (setq txt (vla-addMText
                                  acsp
                                  (setq p (vlax-3d-point
                                                   (mapcar '/ sum
                                                         (list verts
                                                               verts))))
                                  0  StrField))
                  acAttachmentPointMiddleCenter)
            (vla-put-InsertionPoint txt p)
            (ssdel e ss)
            )(princ "\0 Objects found:"))
  (command "_.undo" "_e")
  (princ)
Just be careful if you have some more complex shapes (typically "C" shape) -- label may be outside the closed area.
Message 3 of 14
Yes,
This is what i wanted exactly, Thanks
Can you add Unit "m2" For me in this lisp?
Message 4 of 14
ВeekeeCZ
@Anonymous wrote:
Yes,
ok...
Spoiler
  (vl-load-com)
			;(initget 1 "Y N")
			;(if (eq "Y" ans)
			  ;"_X"
			  ":L";))
		      '((0 . "*POLYLINE")
                        (-4 . "&")
                  sum   '(0 0)
            (setq ptList
                       (mapcar 'cdr
                               (vl-remove-if-not
                                     (entget e))))
            (setq StrField
			       ID
                               "m2"))
                                  acsp
                                                   (mapcar '/ sum
                                                         (list verts
                                                               verts))))
                                  0  StrField))
            (ssdel e ss)
  (princ)
Message 5 of 14
It is not working on circles.
Message 6 of 14
Kent1Cooper
It's not written to do that.  Curiously, your original code describes itself as only for Polylines, but in fact works on other entity types, too [even Lines! -- it puts 0.00 in for the area].
Here is one that reports in square meters.  But it also says it's just for Polylines.  Maybe you can easily take the part of it that determines the text content and transfer that into your code in Post 1 [and change the description in that, to not be in terms of only Polylines].
Kent Cooper, AIA
Message 7 of 14
ВeekeeCZ
Spoiler
(vl-load-com)
(defun c:PLArea  (/ adoc acsp ss e ptList ID StrField txt p)
  (setq  acsp (vla-get-modelspace (setq adoc (vla-get-activedocument (vlax-get-acad-object)))))
  (vla-startundomark adoc)
			;(initget 1 "Y N")
			;(if (eq "Y" ans)
			  ;"_X"
			  ":L";))
		      '((-4 . "<OR")
                        	(0 . "CIRCLE")
                        	(-4 . "<AND")
                        		(0 . "*POLYLINE")
                        		(-4 . "&")
                        		(70 . 1)
                        	(-4 . "AND>")
                        (-4 . "OR>")
                  sum   '(0 0)
                  verts (cond ((cdr (assoc 90 (entget e))))
                              (1)))
            (setq ptList (mapcar 'cdr
                                 (vl-remove-if-not
                                   '(lambda (x)
                                      (= (car x) 10))
                                   (entget e))))
            (setq StrField (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                                   ID
                                   "m2"))
                                  acsp
                                                   (mapcar '/ sum
                                                         (list verts
                                                               verts))))
                                  0  StrField))
            (ssdel e ss)
    (princ "\n0 Objects found:"))
  (vla-endundomark adoc)
  (princ)
Message 8 of 14
gpcattaneo
Try this...
Message 9 of 14
ВeekeeCZ
@gpcattaneo, I must admit I'm impressed!! Nice solution!
-- haven't dig into algorithm much -- do you somehow test if a text is really inside?
I tried a little test... not really hard, these are the only shapes I've drawn...
http://autode.sk/2dXLZB5
Message 10 of 14
F.Camargo
@gpcattaneo wrote:
Try this...
Fantastic, Gian!!
It will be better if the texts were as a field. Smiley Happy
Fabricio
Message 11 of 14
gpcattaneo
Thanks Smiley Happy
@ВeekeeCZ
Increase the value of "step1" on very narrow polygons.
@F.Camargo
The field version...
Message 12 of 14
F.Camargo
Just amazing Gian!!
Thank you
Message 13 of 14
 I tried this lisp it is very useful to me
but..why the result values are too big
how can  I reduce the size of this lisp text
Message 14 of 14
gpcattaneo
Change the TEXTSIZE system variable.
