02:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This lisp is used to Calculate the area of an object in square feet.
1. Please Edit it to calculate in Square meter.
2. Please Edit it to calculate for multiple objects.
;;; AreaText.LSP ver 3.0 ;;; Command name is AT ;;; Select a polyline and where to place the text ;;; Sample result: 2888.89 SQ. FT. ;;; As this is a FIELD it is updated based on the FIELDEVAL ;;; or the settings found in the OPTIONS dialog box ;;; By Jimmy Bergmark ;;; Copyright (C) 2007-2010 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; 2007-09-05 - First release ;;; 2009-08-02 - Updated to work in both modelspace and paperspace ;;; 2010-10-29 - Updated to work also on 64-bit AutoCAD ;;; Uses TEXTSIZE for the text height (defun Get-ObjectIDx64 (obj / util) (setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)))) (if (= (type obj) 'ENAME)(setq obj (vlax-ename->vla-object obj))) (if (= (type obj) 'VLA-OBJECT) (if (> (vl-string-search "x64" (getvar "platform")) 0) (vlax-invoke-method util "GetObjectIdString" obj :vlax-False) (rtos (vla-get-objectid obj) 2 0) ) ) ) (defun c:AT (/ entObject entObjectID InsertionPoint ad) (vl-load-com) (setq entObject (vlax-ename->vla-object(car (entsel))) entObjectID (Get-ObjectIDx64 entObject) InsertionPoint (vlax-3D-Point (getpoint "Select point: ")) ad (vla-get-ActiveDocument (vlax-get-acad-object)) ) (vla-addMText (if (= 1 (vla-get-activespace ad)) (vla-get-modelspace ad) (if (= (vla-get-mspace ad) :vlax-true) (vla-get-modelspace ad) (vla-get-paperspace ad) ) ) InsertionPoint 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " entObjectID ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%" )) )
