Block Text Shifting
Block Text Shifting
Block Text Shifting
Hello Autodesk Community,
I am encountering an issue where the attribute text associated with a block is shifting whenever I add an attribute to the block.
For example, when I add an attribute, the ATTSYNC command runs as well as "TORIENT" and any text that was moved on the block using the blue grip handles reverts back to the original text position as the block was originally designed. Is there any way to retain the text positions while still adding the new attributes?
Your help would be very much appreciated!
Thank you.
I have had this issue with annotative block attributes.  My fix was ANNORESET.
