Message 1 of 29
Rotate Multiple Blocks Around Their Center
09:32 AM
Does anyone know of a way to rotate multiple blocks around their centers instead of around their basepoint? I have a number of blocks, already on the drawing, with visible text attributes that I need to rotate all at once instead of individually rotating them.
For example, I have a block that is 20''W X 10''H. I would like the rotation to occur around its center, not the insertion point, which in this case would be located at 1/2 of the width and 1/2 of the height of the block. Reinserting the blocks would not be efficient as each block contains custom attributes entered manually.
Thank you.
