burst block with script
Message 1 of 18
I need a script that will burst a specific block by name. Is this possible? I tried to use this but it didn't quite work
( Command "burst" (SSGET "X" '((0 . "INSERT") (2 . "PCS Border Info_22X34" ))) "" )
Replies (17)
Message 2 of 18
ВeekeeCZ
If your blocks are NOT dynamic, then try this.
(progn (sssetfirst nil (SSGET "X" '((0 . "INSERT") (2 . "PCS Border Info_22X34" )))) (c:burst))
BURST is Express Tools command - it's a LISP actually, not a regular autocad's build-in command.
Message 3 of 18
I guess that explains why it didn't work. Unfortunately, that code didn't do anything either. The log shows this
Command: (progn (sssetfirst nil (SSGET "X" '((0 . "INSERT") (2 . "PCS Border Info_22X34" )))) (c:burst))
Initializing...1 found
Command:
Message 4 of 18
ВeekeeCZ
You did not answer... it looks like your block is a dynamic.
Anyway, try this code.
And check a PICKFIRST sysvar, pre-selection must be allowed.
(vl-load-com)
(defun c:BurstBorder ( / e ss objs blk) ; by name
  (setq e "PCS Border Info_22X34" ; (getstring T "\nType block name(s) to select (comma-delimited list or wildcards): ")
        objs (ssadd))
  (if (setq ss (ssget "_X" '((0 . "INSERT"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq name (strcase (vla-get-effectivename (vlax-ename->vla-object (setq blk (ssname ss (setq i (1- i))))))))
        (if (wcmatch name (strcase e))
          (ssadd blk objs)))
    (if (> (sslength objs) 0)
      (progn
	(sssetfirst nil objs)
	(c:burst)))))
  (princ)
Message 5 of 18
sorry about that. The block is definitely dynamic. I verified PICKFIRST is set to 1. Unfortunately, as far as I can tell, the code didn't do anything.
I attached a sample drawing with the block in it for reference.
Message 6 of 18
ВeekeeCZ
Hmm.... dunno what issue you're experiencing, but it works for me.
See the SCREENCAST
Message 7 of 18
Forgive my ignorance....I'm not quite sure what you're using to run it but I usually use script pro by pasting it into notepad and saving it as a .scr. could that have something to do with it?
Message 8 of 18
ВeekeeCZ
I should have told you - this is the LISP, not a script.
Read HERE how to use it. Basically, save it as *.lsp and load with APPLOAD.
I used VLIDE, which is build-in LISP editor. You can use that as well.
Message 9 of 18
Thanks for your help thus far. I'm going to have to run this lisp on over 1,000 drawings. I'm trying to work out the syntax to have a script run the lisp so I don't have to manually open every drawing. So far I've got this but I don't quite know what I'm doing.
(load "Path to .lsp" "Failed to Load")
(defun c:BurstBoarder ( )
Message 10 of 18
ВeekeeCZ
I would suggest just copy-paste the whole code at the end of ACADDOC.lsp, save it.
Use modified code, to run thru all layouts. (the previous code works on current layout only)
And for a SCRIPT use just a command name: BurstBorder (and some other commands to exit, save ...so on)
(vl-load-com)
(defun c:BurstBorder ( / adoc e ss objs blk)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for layt (vla-get-layouts adoc)
    (if (not (= (setq lname (vla-get-name layt)) "Model"))
      (progn
        (setvar 'CTAB lname)
              objs (ssadd))
          (progn
                (ssadd blk objs)))
              (progn
                (c:burst))))))))
  (princ)
Message 11 of 18
Thanks for you help.
I'm trying really hard to follow what you're saying and I think I understand but I can't locate the ACADDOC.lsp file.... I typed
(findfile "acaddoc.lsp")
and it returned nil
Message 12 of 18
ВeekeeCZ
Good, then create one (it's a regular txt file with lisp extention). Save it to some of your support search file path (see Options/Files...) e.g.
C:\Users\UserName\appdata\roaming\autodesk\autocad 2015\r20.0\enu\support
You might add this location between Trusted Path as well (Options/Files...)
See HELP why you do that.
Message 13 of 18
Thanks for your patience in working with me. I'm trying but I just cant seem to get it to show up in the command prompt.
I have the lisp you wrote saved as ACADDOC.lsp in the folder you specified. The path is added to the Support File Search Paths, Trusted Locations and even Working. When I type the name of the function, it doesn't show up.
(findfile "ACADDOC.LSP") still returns nil
setting LEGACYCODESEARCH to on changes nothing
setting SECURELOAD to 0 changes nothing
suggestions?
Message 14 of 18
ВeekeeCZ
Dunno. Maybe try another path from your Search path...
You may create the file with just a test prompt e.g. (princ "\nACADDOC.lsp LOADED"), then you should see that in command line while opening any new/exist drawing.
If that fails, you may use another way to load the file automatically. Use APPLOAD command, in dialog there is START UP SUITE, put the *.lsp file in there. But this way is less reliable, especially when you gonna use that within the script for 1000 files...
Good luck.
Message 15 of 18
The problem was that I didn't need to add the .lsp extension when I saved the file. It was reading it as "ACADDOC.LSP.LSP". Once I removed the extra extension it worked perfectly. thanks!
Message 16 of 18
Any chance i can get this where it doesn't force you to switch to paper space? Can someone also point out exactly where i need to put the name of the block im looking for?
Message 17 of 18
ВeekeeCZ
That was kind of the point - to go thru all the layouts. Now I am not sure what you want... following routine burst all the block of specified name in current tab (layout/model) only.
(vl-load-com)
(defun c:BurstMyBlocks ( / adoc e ss objs blk)
  (setq e "MyBlock" ; you can use wildcards or comma-delimited
        objs (ssadd))
    (progn
          (ssadd blk objs)))
        (progn
          (c:burst)))))
  (princ)
Message 18 of 18
tomasz.pakiela
Would it be possible to burst blocks with selected name that are inside other blocks also?
