Blatant ask for Lisp help :-)
Ok, I am on the scrounge if I can please.
Can someone put together a couple of Lisps for me? I am using Acad2014 if that makes a difference.
The first:
- upon pressing any single keystroke
- activate command 'ROTATE3D'
- user selects item on screen
- sub command option value 'x-axis'
- value '-90'
- return back to where we were
The second:
- user command key 'k'
- activates command '3DORBITCTR'
- the command is expecting user input 'specify orbit center point'
- Lisp to automatically selects the snap point 'node'
- user selects the desired node on screen and holding it down is able to rotate the block in 3D
- upon releasing, return back to where we were
Hopefully someone can help.....?
Thanks guys.
R
Sea-Haven
This is question 1
(defun c:3 ( / ent pt )
(setq ent (entsel "\Pick object to rotate3d"))
(setq pt (Getpoint "\nPick point of rotation"))
(command "rotate3d" ent "" "X" pt 90)
Question 2 I would not use "k" as autocad may use in future
(defun c:2 ( / )
(command "3DORBITCTR" "_node" (getpoint) pause)
Hi Sea.haven,
Big, big thank you for those.
One query, the first
I realised that after selecting the point, the user input should be 'x' as you have done but the next bit 'specify a point of the x axis' should always be the default of 0,0,0 rather than asking for user input. And then, the -90.
Do I simply delete the
(setq pt (Getpoint "\nPick point of rotation")) and instead change the next line to be:
(command "rotate3d" ent "" "X" "" -90)
Is this correct?
TIA
Sea-Haven
(command "rotate3d" ent "" "X" "0,0,0" 90)
(command "rotate3d" ent "" "X" (list 0.0 0.0 0.0) 90)
Safer than ""
Thanks.
That's fantastic and spot on!
