Change back color ar lineweight to "by layer"
Angelswing91
Angelswing91
Hi all,
i tried to modificate this code by adding color and lineweight
(vl-load-com)
(defun C:CPV (/ ss i pl n); = Circles at Polyline Vertices
(if (setq ss (ssget '((0 . "LWPOLYLINE"))))
(repeat (setq i (sslength ss)); then
(setq pl (ssname ss (setq i (1- i))))
(repeat (setq n (cdr (assoc 90 (entget pl))))
(command "color" 3 "lweight" 0.3 "_.circle" (vlax-curve-getPointAtParam pl (setq n (1- n))) 0.8)
); repeat [vertices]
); repeat [Polylines]
); if
); defun
But after this command, on current layer it leaves selected color and lineweight, it is possible make it set back to by layer after this lisp?
CodeDing
@Angelswing91 ,
I made some edits, but this way is faster when used and will not fill up your command history with a bunch of nonsense that we don;t need the user to see.
(defun c:CPV ( / ss osm pl i j)
;helper function
  (defun CPV_Circle (cen rad clr lwt)
    (entmakex (list '(0 . "CIRCLE") (cons 10 cen) (cons 40 rad)
		    (cons 62 clr) (cons 370 (fix (* 100 lwt)))))
  );defun
  (progn
    (setq osm (getvar 'OSMODE)) (setvar 'OSMODE (logior 16384 osm))
      (repeat (setq j (cdr (assoc 90 (entget pl))))
	(CPV_Circle (vlax-curve-getPointAtParam pl (setq j (1- j))) 0.8 3 0.3)
      );repeat
    );repeat
    (setvar 'OSMODE osm)
  );progn
);if
(prompt "CPV Complete.")
(princ)
);defun
If you want to stick with your method, you should change it to something like this. You were close but we needed to create the circle first:
  (command  "_.circle" (vlax-curve-getPointAtParam pl (setq n (1- n))) 0.8)
  (command "_.CHPROP" (entlast) "" "color" 3 "lweight" 0.3 "")
Best,
~DD
Sea-Haven
What about using (setvar 'cecolor 3) and line width rather than hard coding in your cpv and at end (setvar 'cecolor 256)
ВeekeeCZ
Perhaps just like this would be enough.
(defun c:CPV ( / s i p)
  (if (setq s (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (foreach p (entget (ssname s (setq i (1- i))))
	(if (= (car p) 10)
	  (entmake (list '(0 . "CIRCLE") p '(40 . 0.8)))))))
  (princ)
Kent1Cooper
@Angelswing91 wrote:
.... color and lineweight, it is possible make it set back to by layer after this lisp?
Directly as A minimal adjustment to yours, if you like, just do exactly that after drawing the Circle, in the same way that you changed them:
  (command
    "color" "BYLAYER" "lweight" "BYLAYER"
  ); command
Kent Cooper, AIA
