Help with Entmakex Hatch - Returning dxf errors with variables in point list
SORONW
SORONW
I'm trying to adapt this bit of code I found over at http://www.theswamp.org/index.php?topic=4814.60.
(defun C:Test ()
(entmakex-hatch '(((0 0) (1 0) (1 1) (0 1))
                (/ pi 2)
                "SOLID"
                2.0
(defun C:Test2 ( / a)
(setq a 1)
(entmakex-hatch '(((0 0) (a 0) (a a) (0 a)) ) (/ pi 2) "SOLID" 2.0 ))
(defun entmakex-hatch (L a n s) ;; By ElpanovEvgeniy ;; L - list point ;; A - angle hatch ;; N - name pattern ;; S - scale ;; returne - hatch ename (entmakex (apply 'append (list (list '(0 . "HATCH") '(100 . "AcDbEntity") '(410 . "Model") '(100 . "AcDbHatch") '(10 0.0 0.0 0.0) '(210 0.0 0.0 1.0) '(2 . "SOLID" ) (if (= n "SOLID") '(70 . 1) '(70 . 0) ) ;_ if '(71 . 0) (cons 91 (length l)) ) ;_ list (apply 'append (mapcar '(lambda (a) (apply 'append (list (list '(92 . 7) '(72 . 0) '(73 . 1) (cons 93 (length a))) (mapcar '(lambda (b) (cons 10 b)) a) '((97 . 0)) ) ;_ list ) ;_ apply ) ;_ lambda l ) ;_ mapcar ) ;_ apply (list '(75 . 0) '(76 . 1) (cons 52 a) (cons 41 s) '(77 . 0) '(78 . 1) (cons 53 a) '(43 . 0.) '(44 . 0.) '(45 . 1.) '(46 . 1.) '(79 . 0) '(47 . 1.) '(98 . 2) '(10 0. 0. 0.0) '(10 0. 0. 0.0) '(451 . 0) '(460 . 0.0) '(461 . 0.0) '(452 . 1) '(462 . 1.0) '(453 . 2) '(463 . 0.0) '(463 . 1.0) '(470 . "LINEAR") ) ;_ list ) ;_ list ) ;_ apply ) ;_ entmakex ) ;_ defun
The first test works well, but things start to break down when I try using variables as part of the point list,. I've tried using (list) to build my list but that just returns dxf errors.
Any advice? I'm still learning of the complexities of DXF codes so I'm sure the issues lies in there, I'm just not sure where to start.
ВeekeeCZ
These are the basics!!
I would discourage you from using that function. It's quite advanced. Better stick with (command).
(entmakex-hatch
  (list (list '(0 0)
	      (list a 0)
	      (list a a)
	      (list 0 a)))
  (/ pi 2)
  "SOLID"
  2.0 ))
SORONW
Thanks for the guidance.
I tried that string prior and had still had issues.This led me to dig a little deeper and it looks like the problem wasn't the point list, but rather this little line here
     (if (= n "SOLID")
           '(70 . 1)
           '(70 . 0)
          ) ;_  if
Removing the conditional and leaving '(70 . 0) fixed the issue, But thanks for confirming a list structure regardless.
ВeekeeCZ
Weird... it should stay 1 for the SOLID.
Anyway, if you read the linked thread from the end, you will find that the issue was fixed HERE  by VVA. He keeps the toggle for '70.
