ATTEDIT problem
7 REPLIES 7
Message 1 of 8
john.uhden
301 Views, 7 Replies
ATTEDIT problem
If you invoke the ATTEDIT command, it allows you to pick any part of a block insertion (with attributes) and it brings up a nice list of all the attributes enabling you to edit each value.
BUT, if I have preselected an insertion (as an ename named e), the (command "_.attedit" e) fails.
It fails even if I feed the command the ename of one of its attributes.
How can I get around that shortcoming without having to build my own DCL?
John F. Uhden
7 REPLIES 7
Message 2 of 8
john.uhden
in reply to: john.uhden
I found it.  The command to use is EATTEDIT.
John F. Uhden
Message 3 of 8
paullimapa
you can also do this:
(initdia)(command "_.attedit" e)
Paul Li
IT Specialist
@The Office
Message 4 of 8
john.uhden
in reply to: paullimapa
@paullimapa ,
Thanks, but according to the Help, EATTEDIT is not one of the commands that makes use of initdia.
(command "_.EATTEDIT" e) worked for me without initdia.  Maybe it was just because I had a lot of attributes.
John F. Uhden
Message 5 of 8
paullimapa
Yes but _.attedit does require it since you’re wondering why that didn’t work
Paul Li
IT Specialist
@The Office
Message 6 of 8
john.uhden
Thanks, @paullimapa ,
That's fair enough.
BTW, I tried adding attributes via BEDIT, but they don't show up after a Bclose/Save.  Might it be because I had defined the block as non-explodable.  If that's the case, how do I change it to explodable?
John F. Uhden
Message 7 of 8
Kent1Cooper
@john.uhden wrote:
..., I tried adding attributes via BEDIT, but they don't show up after a Bclose/Save.  ....
After ATTSYNC?
Kent Cooper, AIA
Message 8 of 8
john.uhden
Ahah!  ATTSYNCH fixed it.
John F. Uhden
Forma Design Contest
AutoCAD Beta
