If you invoke the ATTEDIT command, it allows you to pick any part of a block insertion (with attributes) and it brings up a nice list of all the attributes enabling you to edit each value.
BUT, if I have preselected an insertion (as an ename named e), the (command "_.attedit" e) fails.
It fails even if I feed the command the ename of one of its attributes.
How can I get around that shortcoming without having to build my own DCL?
John F. Uhden
Solved by Kent1Cooper. Go to Solution.
Solved by john.uhden. Go to Solution.
you can also do this:
(initdia)(command "_.attedit" e)
Thanks, but according to the Help, EATTEDIT is not one of the commands that makes use of initdia.
(command "_.EATTEDIT" e) worked for me without initdia. Maybe it was just because I had a lot of attributes.
John F. Uhden
Yes but _.attedit does require it since you’re wondering why that didn’t work
Thanks, @paullimapa ,
That's fair enough.
BTW, I tried adding attributes via BEDIT, but they don't show up after a Bclose/Save. Might it be because I had defined the block as non-explodable. If that's the case, how do I change it to explodable?
John F. Uhden
@john.uhden wrote:
..., I tried adding attributes via BEDIT, but they don't show up after a Bclose/Save. ....
After ATTSYNC?
