Any alternative for srxtext.vlx ?
jtm2020hyo
Message 1 of 31
jtm2020hyo
https://www.cadstudio.cz/en/apps/srxtext/
I found this .vlx but does not work, at least for me, I think this because of the need to pay. So I need an alternative.
Replies (30)
Message 21 of 31
vladimir_michl
Cameras are views. Views are already there - under "V".
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 22 of 31
jtm2020hyo
thanks, work perfectly, sorry if I did waste your time.
please keep developing more  softwares too awesome like this.
Message 23 of 31
jtm2020hyo
excuse me, it's possible to add an option to export to CSV?
Message 24 of 31
vladimir_michl
Export? RRename just changes object names - why export? Or do you mean export-rename-import?
Message 25 of 31
jtm2020hyo
yes, it could be great.
Message 26 of 31
vladimir_michl
Here it is:
https://www.cadforum.cz/cadforum_en/renamecsv-rename-layers-layouts-views-linetypes-using-excel-tip1...
RenameCSV renames DWG symbol tables using Excel (or other app, over CSV file export/import).
Message 27 of 31
jtm2020hyo
thanks a lot, sir.
Message 28 of 31
joel.bennettFVVY2
Using SRXTEXT2 I am struggling to find the right regex to search mtext that contains:
MODEL: DP DA2300
MODEL: TH-55CQE1W
And replace it with the following:
DP DA2300 [1]
TH-55CQE1W [1]
The main problem is I do not know how to find a line break. I have tried \r\n and \P
Any help would be greatly appreciated.
Message 29 of 31
vladimir_michl
If the lines are in a single MText, you can use e.g. this regexp:
Command: SRXTEXT2
Search texts using [Regular expression/Exact string/Substring] <Substring>: r
Enter the searched pattern: .+: (.+)\\P.+: (.+)
Enter the replace pattern ($1$2 for regex captures): $1 [1]\P$2 [1]
Search only in [Layer/All] <All>:
Search only [Selected/All] <All>:
Number of searched entities: 3
MODEL: DP DA2300\PMODEL: TH-55CQE1W-->DP DA2300 [1]\PTH-55CQE1W [1]
Perform [Replace/Yes to all/Skip/skipAll/Exit]? <Skip>: r
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
Message 30 of 31
joel.bennettFVVY2
Thank you that worked. I have one more request
I have MTEXT in the format below, I want to capture the text in bold using srxtext2
MODEL: DP DA2 [60-1221-01]
MANUFACT: EXTRON
DESCRIPT2: DPORT DA
DESCRIPT1:
DPORT OUT 1
MODEL: TH-55CQE1W
MANUFACT: PANASONIC
DESCRIPT2: 55" 4K LED TV
DESCRIPT1:
HDMI IN 1
Desired Result
DP DA2: 1
TH-55CQE: 1
Note from the model tag, I am wanting to capture the first eight characters (ignoring white space) OR up until the first left bracket, whatever comes first.
Message 31 of 31
vmichl_cs
Should be something like (simplified to just the first line of the text):
Command: SRXTEXT2
Enter the searched pattern: Model: ([^\[]{1,8}).*
Number of searched entities: 2
MODEL: TH-55CQE1W-->TH-55CQE
