Macro to freeze certain layers, then align command and then thaw those layers
Message 1 of 11
I'm using 2013 OEM version.
I want to thaw the information layer, use the align command then by choosing 2 points only, and freeze the informations layaer again. I know you have to use "\" to wait for user input, but I can't figure out how. Can any body help? And Merry Christmas by the way :).
^C^C-layer;t;_INFORMATION;;_align;all;-layer;f;_INFORMATION;;
Accepted solutions (4)
Replies (10)
Message 2 of 11
dbhunia
 Try this ....... Due to this two "\\" you can "Specify first source point:" and "Specify first destination point:" (two input)...... Hopefully you can manage the rest.......
^C^C-layer;t;_INFORMATION;;_align;all;;\\;-layer;f;_INFORMATION;;
Try this ....... For "Specify first source point:", "Specify first destination point:", "Specify second source point:","Specify second destination point:" and "Scale objects based on alignment points? [Yes/No] <N>: n"......
^C^C-layer;t;_INFORMATION;;_align;all;;\\\\;n;-layer;f;_INFORMATION;;
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
Moshe-A
@Anonymous hi,
^C^CLayer thaw _information;;align all;;\\\\;;Layer freeze _information;;
by the way:
when layer command is coming from menu macro it runs from command line so there is no need to call it as -layer
moshe
Message 4 of 11
Well that's what I thought to write the macro as well, but it did not work.
I opened the command line window and did the follownig tweak. This one works. Thank you!
^C^C-layer;t;_INFORMATION;;_align;all;;\\\\;;n;-layer;f;_INFORMATION;;
Message 5 of 11
Would this work too?
I want to change the user input of the destionation points to a known point.
So:
would change into
;\ 0,0,0 \ 6000,0,0;
In the command window when I input 0,0,0 manually, it returns @0,0,0
Going to try it now.
Message 6 of 11
IT WORKS!
Message 7 of 11
dbhunia
It's good you have got your solution.......
But when I am using this........(In AutoCAD 2017 & 2018)....(Here my Layer name is "1")
^C^C-layer;t;1;;_align;all;;\\\\;;n;-layer;f;1;;
I am getting this "Unknown command "N".  Press F1 for help.".......
^C^C-layer;t;1;;_align;all;;\\\\;n;-layer;f;1;;
I am getting this.....
Debashis Bhunia
Message 8 of 11
Yes, very strange.
I had to use the double ";" to get it running.
It does odd things sometimes. Don't know why either.
Message 9 of 11
Kent1Cooper
@Anonymous wrote:
....  I ... did the follownig tweak. This one works. ...
Did that really work?  It shouldn't....  The first ; after the \\\\ would accept the default <continue> option instead of a third reference point, and the second ; would accept the default about whether to scale things, and that would complete the command.   That's why when the n comes along, it's waiting for a command name, but it doesn't know that as one.  Did you really not  get the problem in the first image in @dbhunia's Message 7?
Aside from that, I would suggest you also include turning on  that Layer, in case it might have been turned off in addition to [or possibly instead of] being frozen, and also unlocking it, just in case.  And depending on your version, you might also need a REGEN command after the LAYER command, to "bring to life" things on a Layer that was frozen [it seems to do so without REGEN in Acad2019, but it hasn't always done so].
Kent Cooper, AIA
Message 10 of 11
Kent1Cooper
@Anonymous wrote:
.... I had to use the double ";" to get it running. ....
That was appropriate in that portion of the code in Message 3 [two semicolons without  following them with an n and another semicolon].  I think the problem would have been from adding  n;  after  the two of them, instead of replacing the second one  with  n; .
BUT you don't need to spell out the n option at all -- that answer is always the default, even after you've used the command and chosen the Yes option, which it doesn't remember  [perhaps as a safeguard against unintended effects].  So just  ....align all;;\\\\;;Layer....  should work in any situation.
Kent Cooper, AIA
Message 11 of 11
dbhunia
Yes @Kent1Cooper this is the normal behavior of "ALIGN" command in AutoCAD, but @Anonymous is using "AutoCAD 2013 OEM version" and I do not know it's normal behavior that's why I suggest to use "...align;all;;\\\\;n;..." instead of "...align;all;;\\\\;;..." in my 1st post, to force the input "n" for the option "Scale objects based on alignment points? [Yes/No] <N>:", now I am sure the both syntax (with "No" options only for "Yes" the syntax should be "...align;all;;\\\\;y;...") should work perfectly after seeing @Anonymous's 4th Message.
And I also know that the syntax in  @Anonymous's 4th Message is not the correct one.....
But @Anonymous as you stated....
@Anonymous wrote:
Yes, very strange.
For this I would like to see the "error message" and the drawing also in which you are facing problem.....
Debashis Bhunia
