Any alternative for srxtext.vlx ?
jtm2020hyo
Message 1 of 31
jtm2020hyo
https://www.cadstudio.cz/en/apps/srxtext/
I found this .vlx but does not work, at least for me, I think this because of the need to pay. So I need an alternative.
Replies (30)
Message 2 of 31
Luís Augusto
Does not the 'Find' command meet your needs?
Find and Replace Dialog Box (FIND)
About Finding and Replacing Text
or you can have a look at these routines
Regular expressions
Message 3 of 31
jtm2020hyo
Regular expressions
Wild Cards used for the command FIND is very limited. I need a REGEX alternative like srxtext.vlx.
Before leave an answer to your linked post I will need test those lisp routines.
For now I can just say thank for your help.
Message 4 of 31
jtm2020hyo
I was testing the regex lisp and that work but does not what I need. (maybe I need a small guide)
I need to FIND/REPLACE option.
Is there any other regex routine to test?
or maybe do you know a complete guide for "srxtext.vlx"
Message 5 of 31
Luís Augusto
I think this might help you better understand regular expressions.
Have a great year and good studies.
https://docs.microsoft.com/en-us/dotnet/standard/base-types/regular-expression-language-quick-refere...
https://medium.com/tech-tajawal/regular-expressions-the-last-guide-6800283ac034
Luís Augusto
Message 6 of 31
vladimir_michl
Most of the srxText functionality is free - what does not work for you?
See number of examples: https://www.cadforum.cz/cadforum_en/tips.asp?t=srxText
Vladimir Michl, www.cadstudio.cz
Message 7 of 31
jtm2020hyo
hanks for your help friend.
Yes I was studing SRSTXT.vlx a time ago.
I remember that srxtexthave 2 kinds of regex. one basic for srxtext and another more complex and complet for srxtext2. I can with the single srxtext, but I need to work with the srxtext2 command.
i found some guides for srxtext2, according to some post srxtext2 use VBscript regex, then I was searching for a guide for VBscript and I tested some examples for srxtext2, but does not works. I tried some examples from their own website and sometimes work and other does not.
so I request a guide for "srxtext2" command.   "srxtext" work perfectly.
Message 8 of 31
vladimir_michl
If you would send a specific case of what doesn't work for you, I can help you. So far, all type of text replacements were successfuly done with the srxText utility.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 9 of 31
jtm2020hyo
hello. sorry for late response.
I was testing again the command srxtext2. but I'm using a different guide.
https://wellsr.com/vba/2018/excel/vba-regex-regular-expressions-guide/
Until now. all work well. but If I find a problem I will report it in this post.
I will keep testing your awesome code. thanks for pay attention.
Message 10 of 31
jtm2020hyo
could add support for rename Model or paper space views, and cameras?
Message 11 of 31
vladimir_michl
srxText is just for drawing texts, we have a similar tool - RRename - for renaming of DWG symbols and tables (Layers, Layouts, Blocks, etc.) - Views and Cameras are not included but I will look at it
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 12 of 31
vladimir_michl
Views (incl. cameras), materials, groups, UCSs, styles and other tables have been now added to the RRename freeware utility - see:
CAD Forum - RENAME on steroids - complex renaming of AutoCAD objects.
Message 13 of 31
jtm2020hyo
wow, so fast, thanks a lot.
Message 14 of 31
jtm2020hyo
I am not sure, maybe I did something bad, but I can not rename cameras and viewports:
Command: RRENAME
Rename [Blocks/Layers/lineTypes/layOuts/Views/Textstyles/Dimstyles/tAblestyles/Materials/viewPorts/Ucs/Groups] <Layers>: p
Use () and $1 for regular expressions, # as counter
Source substring or regex to find (e.g. '(.+)'): test1
Target substring or regex to replace (e.g. '$1_NEW'): test01
; IAcadViewport: A bounded area that displays some portion of a drawing's model space
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff73d50d9a0>
;   ArcSmoothness = 100
;   Center = (5.86559 4.5)
;   Direction = (0.0 0.0 1.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 00000194de03c1a8>
;   GridOn = 0
;   Handle (RO) = "1B72"
;   HasExtensionDictionary (RO) = 0
;   Height = 9.20623
;   LowerLeftCorner (RO) = (0.0 0.0)
;   Name = "$RECOVER_201211223519-0"
;   ObjectID (RO) = 42
;   ObjectName (RO) = "AcDbViewportTableRecord"
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapBasePoint = (0.0 0.0)
;   SnapOn = 0
;   SnapRotationAngle = 0.0
;   Target = (0.0 0.0 0.0)
;   UCSIconAtOrigin = 0
;   UCSIconOn = -1
;   UpperRightCorner (RO) = (1.0 1.0)
;   Width = 12.0
; Property values:
;   ArcSmoothness = 1000
;   Center = (-25.7872 630.066)
;   Direction = (9.54969e-12 -9.09495e-13 43031.8)
;   GridOn = 0
;   Handle (RO) = "20214E0"
;   Height = 20885.3
;   Name = "*Multiple"
;   ObjectID (RO) = 44
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = 0
;   Target = (3043.57 7714.43 15136.2)
;   UCSIconAtOrigin = -1
;   UCSIconOn = -1
;   UpperRightCorner (RO) = (0.75 1.0)
;   Width = 20324.4
; Property values:
;   Center = (0.0 0.0)
;   Direction = (-3254.62 -6672.95 5249.8)
;   GridOn = -1
;   Handle (RO) = "20214E1"
;   Height = 18960.8
;   LowerLeftCorner (RO) = (0.75 0.333333)
;   ObjectID (RO) = 45
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = -1
;   Target = (-531.994 10091.5 3625.44)
;   UCSIconOn = -1
;   UpperRightCorner (RO) = (1.0 0.666667)
;   Width = 18760.6
; Property values:
;   Direction = (-7.27596e-12 0.0 42896.1)
;   GridOn = -1
;   Handle (RO) = "20214E2"
;   Height = 89935.3
;   LowerLeftCorner (RO) = (0.75 0.0)
;   ObjectID (RO) = 46
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = -1
;   Target = (42635.2 15883.7 6532.86)
;   UCSIconOn = -1
;   UpperRightCorner (RO) = (1.0 0.333333)
;   Width = 88032.2
; Property values:
;   Center = (2957.89 -2170.28)
;   Direction = (13182.0 -38283.3 3.63798e-12)
;   GridOn = -1
;   Handle (RO) = "202152E"
;   Height = 35288.4
;   LowerLeftCorner (RO) = (0.75 0.666667)
;   Name = "*Active"
;   ObjectID (RO) = 47
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = 0
;   Target = (2617.57 9798.53 15130.9)
;   UCSIconOn = -1
;   Width = 34533.6
; Property values:
;   Center = (-661.437 -260.898)
;   GridOn = -1
;   Handle (RO) = "2021C5B"
;   HasExtensionDictionary (RO) = -1
;   Height = 26035.1
;   Name = "*Active"
;   ObjectID (RO) = 48
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = 0
;   UCSIconOn = -1
;   Width = 25358.6
; Property values:
;   Center = (-844.851 -5486.28)
;   Direction = (-1.09139e-11 0.0 49988.5)
;   GridOn = -1
;   Handle (RO) = "2021C5C"
;   Height = 27234.9
;   Name = "*Active"
;   ObjectID (RO) = 49
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = 0
;   Target = (2515.05 9566.59 15368.0)
;   UCSIconOn = -1
;   Width = 26652.4
; Property values:
;   Center = (5887.19 -10069.5)
;   Direction = (-14436.2 -29598.7 23286.1)
;   GridOn = -1
;   Handle (RO) = "2021C5D"
;   Height = 22222.5
;   Name = "*Active"
;   ObjectID (RO) = 50
;   OrthoOn = 0
;   OwnerID (RO) = 43
;   SnapOn = 0
;   UCSIconOn = -1
;   Width = 21985.3
Performed 0 rRenames
Command:
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Automatic save to C:\Users\JTM2020hyo\AppData\Local\Temp\Camaras 1_1_16600_23a8f365.sv$ ...
Command: Updating Indexes for block *Model_Space
Done.
... but with layers work perfectly.
Message 15 of 31
jtm2020hyo
attached file where I was testing the last version of rrename.vlx
Message 16 of 31
vladimir_michl
Sorry, there was a debug message forgotten in the code (please re-download the updated version from cadstudio.cz or cadforum.cz). I have tested the view/camera rename on your DWG and it seems to work fine - performed change from "16500" to "xxxx".
Message 17 of 31
jtm2020hyo
I tried this:
RRename
viewPort
test1
test2
Command: RRENAME
Rename [Blocks/Layers/lineTypes/layOuts/Views/Textstyles/Dimstyles/tAblestyles/Materials/viewPorts/Ucs/Groups] <viewPorts>:
Source substring or regex to find (e.g. '(.+)'): 'test1'
Target substring or regex to replace (e.g. '$1_NEW'): 'test01'
Command:
...at the same attached file, Did I do something wrong?
Message 18 of 31
jtm2020hyo
PD: I tried since AutoCAD 2021 and AutoCAD Arch/MEP 2021
Message 19 of 31
vladimir_michl
I can see two problems:
- enter the search/replace strings without quotes - i.e.: test1, not 'test1'
- the "test1" is probably a View, not a Viewport (looking into your sample DWG)
Message 20 of 31
jtm2020hyo
sorry, I always thought than View=Viewports, RRename.vlx works perfectly.
image.pngimage.png\
Command: RRENAME
Rename [Blocks/Layers/lineTypes/layOuts/Views/Textstyles/Dimstyles/tAblestyles/Materials/viewPorts/Ucs/Groups] <layOuts>: p
Source substring or regex to find (e.g. '(.+)'): 16500
Target substring or regex to replace (e.g. '$1_NEW'): xxx
 16500->xxx
Performed 1 rRename
Command:
Command:
Command:
Command: _+vports
Tab index <0>: 1 Regenerating model.
thanks a lot.
but how can I use rrename.vlx with cameras? cameras are not views? if not, could add support for views?
Command: RRENAME
Rename [Blocks/Layers/lineTypes/layOuts/Views/Textstyles/Dimstyles/tAblestyles/Materials/viewPorts/Ucs/Groups] <viewPorts>: p
Source substring or regex to find (e.g. '(.+)'): camera1
Target substring or regex to replace (e.g. '$1_NEW'): camera01
Command:
