Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Visual LISP, AutoLISP and General Customization
Add Wipeout to Perimeter of Block LISP
12 REPLIES 12
Message 1 of 13
anderson51
1469 Views, 12 Replies
Is there a way to add a wipeout to the perimeter of a block without have to draw a polyline?
Anderson
12 REPLIES 12
Message 2 of 13
ronjonp
in reply to: anderson51
Probably best to post your block. Also there is a wealth of information to programmatically add wipeouts HERE.
Message 3 of 13
anderson51
in reply to: ronjonp
I am talking Blocks in general.
Thanks, Ill check out the link.
Message 4 of 13
ronjonp
Sounds good. Have you considered using a solid hatch with color 255,255,255 instead? I setup all my blocks many moons ago like this and it's worked great. :clinking_beer_mugs:
Message 5 of 13
anderson51
Im not sure Im following what you mean, can you post an example of how it turns out?
Message 6 of 13
ronjonp
Sure. The truecolor white prints white so it will hide objects behind it.
Message 7 of 13
Sea-Haven
A new question are you talking an individual block or all blocks of that name. Doing boundaries can be a bit hit miss.
Message 8 of 13
devitg
@anderson51 when @ronjonp  ask you to upload a sample , you say GENERAL BLOCK , and then you ask @ronjonp  to upload a sample.
Reciprocation is good a way to behave.
Message 9 of 13
anderson51
in reply to: Sea-Haven
Individual blocks
Ive never attempted to use the boundary command, Ill have to check it out.
Thanks.
Message 10 of 13
anderson51
I like that idea, never thought of doing that before.
Thanks for the input!
Message 11 of 13
ronjonp
@anderson51 Glad to help! :clinking_beer_mugs: One nice thing about the hatch is you can create it from many different boundaries where wipeouts need straight segment boundaries. I Changed to these when I was having issues with the wipeouts printing black on plans ... but that was over 10 years ago.
Message 12 of 13
Sea-Haven
Using the Bounding box function in vl is the simplest this will give a box around the block based on x y, in saying that it is possible to get the same for a rotated block where the box is to be on an angle. If the block needs a different shape it becomes way harder.
Message 13 of 13
john.uhden
"way harder" is an understatement.  One can not find the irregular limits of a block even by ray-casting and getboundingbox and intersectwith methods because the bounding box is always just a rectangle encompassing the outer limits of the block.  Same is true for mtext.  It would be better to manually add either the wipeout or white-out to the block definition.  Just draw a polyline around the visual limits on a unique layer, say "WIPEOUT" and fill it using the preferred method.  I prefer using wipeouts.
John F. Uhden
AutoCAD Inside the Factory
