Combine code to make it even better
djurk_haas
Message 1 of 32
djurk_haas
The code below does what I want, but of course I want more:
  • How can I integrate Lee_Mac's code (and actually I want 3 digits instead of 4).
  • How can I stote the attribute value of the tag "TAPPUNT/KEERKLEP"  into a variable " tapkeer"  (to make the comment out code work)
(defun c:TP-change (/ ss i e tapkeer bouwdeel int)
(vl-load-com)
(if (setq ss (ssget ":S" '((0 . "insert")(66 . 1)(2 . "`*U*,TAPPUNT_CZE"))))
(repeat (setq i (sslength ss))
(setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) )))
(if (Eq (strcase (vla-get-effectivename e)) "TAPPUNT_CZE")
(foreach itm (vlax-invoke e 'GetAttributes)
; (setq tap "Tappunt")
; (setq keer "Keerklep")
; (setq nrtappunt "NUMMER_TAPPUNT")
; (setq nrkeerklep "NUMMER_KEERKLEP")
; (cond ((= tapkeer tap) (setq nr nrtappunt))
; ((= tapkeer keer) (setq nr nrkeerklep))
; (t (prompt "N.v.t.: Tappunt onder/boven")))
(if (eq (vla-get-tagstring itm) "NUMMER_TAPPUNT")
(vla-put-textstring itm (getstring "\nTappuntnr: ") )))
(princ)
Code van Lee_Mac:
(defun c:4digits ( / int )
(while
(and
(progn
(initget 6)
(setq int (getint "\nEnter a 4-digit number <Exit>: "))
(not (wcmatch (itoa int) "####"))
(princ "\nThat's not 4-digits!")
(if int
(princ (strcat "\nYou entered " (itoa int) "."))
(princ "\nUser exited.")
(princ)
Replies (31)
Message 2 of 32
Kent1Cooper
UNTESTED:
(if (eq (vla-get-tagstring itm) "TAPPUNT/KEERKLEP")
  (setq tapkeer (vla-get-textstring itm))
); if
Code van Lee_Mac:
(defun c:3digits ( / int )
(while
(and
(progn
(initget 6)
(setq int (getint "\nEnter a 3-digit number <Exit>: "))
(not (wcmatch (itoa int) "###"))
(princ "\nThat's not 3-digits!")
(if int
(princ)
As for integrating that, for what input(s) do you want the 3-digit number requested?
Kent Cooper, AIA
Message 3 of 32
roland.r71
(vl-load-com)
(setq tappuntnr (c:3digits))
(if tappuntnr (vla-put-textstring itm (itoa tappuntnr) ))))
(princ)
Message 4 of 32
roland.r71
@Kent1Cooper wrote:
UNTESTED:
); if
Code van Lee_Mac:
(while
(and
(progn
(initget 6)
(if int
(princ)
I can't imagine Lee Mac writing that the way it is ...
This only tells you what number you just entered, but there's no return value … 🙄
Code van Lee_Mac:
   (while
      (and
         (progn
            (initget 6)
   int
Message 5 of 32
roland.r71
No response yet, so not sure if you're able to put it all together. As I just had some time to spare, I did just that. It remains UNTESTED, as i don't have a sample to test with.
The code looks incomplete, or part of it is obsolete.
The second cond (in red color) sets a var called nr, but nothing is done with that.
This should do the trick:
(defun c:TP-change (/ ss i e nr bouwdeel itm tapkeer tap keer nrtappunt nrkeerklep)
(vl-load-com)
; Code van Lee_Mac:
(defun 3digits (/ int)
(while
(and
(progn
(initget 6)
int
(if (setq ss (ssget ":S" '((0 . "insert") (66 . 1) (2 . "`*U*,TAPPUNT_CZE"))))
(setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
(cond
((eq (vla-get-tagstring itm) "TAPPUNT/KEERKLEP")
((eq (vla-get-tagstring itm) "TAPPUNT")
(setq tap (vla-get-textstring itm))
((eq (vla-get-tagstring itm) "KEERKLEP")
(setq keer (vla-get-textstring itm))
((eq (vla-get-tagstring itm) "NUMMER_TAPPUNT")
(if (setq nrtappunt (3digits))
(vla-put-textstring itm (itoa nrtappunt))
((eq (vla-get-tagstring itm) "NUMMER_KEERKLEP")
(setq nrkeerklep (vla-get-textstring itm))
(cond
(princ)
Message 6 of 32
pbejse
Now you got me interested too.
@djurk_haas
Do you want to be prompted for "Tappuntnr" for every object?  IT looks as if thats what you're going for.
(vla-put-textstring itm (getstring "\nTappuntnr: "));;<---
And when you say 3 Digits  i believe you are referrring to 3 characters as numbers , to include "001" , "025"  Yes?
Whats with the :S in ssget anyway?
:S Force single object selection only
Is that how you really wanted it? then why the repeat?
Though it still works with multiple selection < which is weird >, but can please confirm want you really want?
Message 7 of 32
djurk_haas
Thanks for  the response!
Unfortunately, I didn't have the opportunity to respond before.
Hopefully I can make it more clear what my intention is with the code:
I have a dynamic block with different visibilitystates (Tappunt, Keerklep, Onder-boven).
The selected visibilitystate is stored within the block in the attribute "TAPPUNT/KEERKLEP".
Depending on this value, the associated attribute must be changed.
So with the chosen visibilitystate "Tappunt" only the attribute value "NUMBER_TAPPUNT" must be changed and if the chosen visibilitystate is "Keerklep" only the attribute value "NUMMER_KEERKLEP" must be changed. Both changes must be an 3 digits number.
Message 8 of 32
pbejse
...changed. Both changes must be an 3 digits number.
We understand that, but question were:
Is this for multiple object selection?
if YES will the user be prompted for the 3 digit value per block?
In NO will it be sequential number based on the one time prompt for 3 digit value?
Message 9 of 32
roland.r71
Dus: dit is niet ok?
Enter a 3-digit number <Exit>: 001
Message 10 of 32
djurk_haas
It is for changing 1 block at a time.
Message 11 of 32
pbejse
This is how I understand from your posted code
(defun c:TP-change  (/  Your3digits data ss i e tapkeer attval tagTo)
(vl-load-com)
(defun Your3digits (msg / int nstr)
 (while
	(and
	    (progn
                (initget 6)
	                (setq int  (getint
	                                 (strcat "\n" msg ": ")))
                  (> int 999)
         (princ (strcat "\nInvalid value"))
  	(setq nstr (itoa int))
        (strcat  (nth (strlen nstr)'(nil "00" "0" "")) nstr)
(setq data '(("Onder-boven" "NUMMER-ONDER-BOVEN")
             ("Keerklep" "NUMMER_KEERKLEP" )
	     ("Tappunt" "NUMMER_TAPPUNT" )
(if (setq ss (ssget ":L"
                  (cond
                        ( (not
                              (and
                            	(setq attval (mapcar '(lambda (at)
                                                        (list (vla-get-TagString at)
                                                              (vla-get-TextString at) at))
                                       				(vlax-invoke e 'GetAttributes)))
                                (setq tapkeer (cadr (assoc "TAPPUNT/KEERKLEP" attval)))
                                (setq tagTo (Assoc
                                                  (Cadr (assoc tapkeer data)) attval))
                        ( (member tapkeer (mapcar 'car (Cdr data)))
			 	 (vlax-invoke e 'Highlight 1)
	                         (vla-put-textstring (caddr tagTo) (Your3digits (car tagTo)))
			 	(vlax-invoke e 'Highlight 0)
                        ( t (print "N.v.t.: Tappunt onder/boven")
  (princ)
Depending on the value of "TAPPUNT/KEERKLEP", the prompt will switch between Tappunt and Keerler
Command: TP-CHANGE
NUMMER_TAPPUNT: 12
NUMMER_KEERKLEP: 45
 HTH
Message 12 of 32
pbejse
@roland.r71
Hey that's not fair?  I need to google transate that
Message 13 of 32
roland.r71
But it does so perfectly (in this case) 😛
Anyway, i think its not. So a different way to get the number will be (likely) required.
As leading zero's are ignored for integers. (so it doesn't even accept it as "3 digit number")
Message 14 of 32
pbejse
Yes, hence my question at post # 6. But i went ahead and wrote a different 3digit thingy.
Your3digits"
We'll see what the OP thinks.
Message 15 of 32
roland.r71
It would appear your thingy got accepted 😄
Message 16 of 32
pbejse
Gotta to have that thingy in there
I'll tell you a secret [ whispering: I wrote the code and had it-the-ready two days ago  😉 ,]
Message 17 of 32
djurk_haas
Here I am again.
In the attachments I have added 2 drawings.
In drawing B the code works fine but in drawing A the code stops halfway?
Maybe a system variable is wrong?
Message 18 of 32
pbejse
Drawing A
And because of that...
You see, the program is reading the attribute value of ""TAPPUNT/KEERKLEP"".. its either of the three
  • Tappunt
  • Keerklep
  • Onder-boven
But as you can see. the value is ###, not included as a valid option
Attribute definition TAPPUNT/KEERKLEP is under the layer "A--L$8-hulplijnen" <-- currently locked
After unlocking and regen...
TADA!!!
Drawing B
Although the same layer is locked but the value of the tag "TAPPUNT/KEERKLEP"  is not ###.... you know what I mean right?
We can however change the code to read the visibility state instead of the  attribute tag "TAPPUNT/KEERKLEP"
A simple quick unlock and regen will solve the issue though
Tell me how it goes..
Message 19 of 32
roland.r71
It has to do with the fields used for tappunt/keerklep
When looking at it with the enhanced attribute editor, the text shows up correctly for drawing B, but for drawing A it displays ####. On the Value line at the bottom, you can (still) see the correct value.
The lisp function however gets the same #### as a result when reading the attribute.
It has nothing to do with the drawing itself, as you can copy from B to A and it still works.
Message 20 of 32
pbejse
Here's the modified code that reads the visibility instead of the attribtues
(defun c:TP-change  (/  Your3digits data ss i en tapkeer  tagTo)
(vl-load-com)
 (while
	(and
	    (progn
                (initget 6)
	                (setq int  (getint
                  (> int 999)
                  (setq en (ssname ss (setq i (1- i))))
                  (cond
                        ( (not
                              (and
                           	(Eq (getpropertyvalue en "BlockTableRecord/Name") "TAPPUNT_CZE")
				(setq tapkeer (getpropertyvalue  en "AcDbDynBlockPropertyVisibility1"))
                                (setq tagTo (Cadr (assoc tapkeer data)))
			 	 (redraw en 3)
			 	 (setpropertyvalue en tagTo (Your3digits tagTo))
			 	(redraw en 4)
  (princ)
HTH
