Action Recorder Shortcuts
Code_x
Code_x
Hi, I'm searching for a method to assign a keyboard shortcut to an action recorder in AutoCAD LT 2024. Is this achievable? Could you please supply instructions on how to accomplish this?  Given the increasing number of action recordings, my preference is to develop either floating buttons or a shortcut for each.
Thank you!
pendean
Community Legend
Community Legend
Thank you!
Did you get a chance to install and use AutoCADLT2024 yet?
LISP can't make a feature that is not present in the program just appear sadly, Action Recorder has never been an AutoCADLT ability from Autodesk. That's true through LT2024. Sorry.
Sea-Haven
Like others just found Action recorder to limited to take seriously, hence all the lisps that are posted here, yes a lisp can be called as a command by typing, pop menu choice, tool bar choice, ribbon choice and tool palette which I have not used.
