LISP FOR PLOT AND to record location
mik501_
mik501_
Is there an ISP or method that will allow me to save the size I set and the space when I choose to print? I won't have to come back and fill in the values ​​every time.
I divided the print into two prints per frame. By printing the upper part and printing the lower part.
I have attached a sample frame. which I will have my work inside The print is 1:1 scale.
Enter the length according to the frame length. Print in half With the top half crossing the two red lines to catch the markpoint. Below, do the same.
mik501_
Frame size can be changed depending on the job.
EnM4st3r
wouldnt that work by just using layouts?
mik501_
I've never tried using it in layout.
Sea-Haven
Just set up a layout true sheet size at a 1:1 scale like a A4 is 210x297 then a mview at about 6mm inside that box a layout all done, don't forget to click on Apply to layout after setting it all up, can even click cancel and it will remember the settings, so plot then ok all done.
EnM4st3r
just watch a turorial on how to use Layouts in autocad, i think that would work best for you,
as you can use multiple layouts for multiple diffrent views and the Plot settings get saved for each layout.
Sea-Haven
Forgot to add once you set up a plot to what you want look at top left button, you can even get the settings from another dwg.
