Hello everyone on the forum.
I have this lisp that reads all blocks with the name X-TEST.
Then it places each block found under the other, according to the value of the TAG parameter.
(defun c:TEST ( / ss blkRef insPt atts att tagValue newBlkRef )
(vl-load-com)
(setq ss (ssget "X" '((0 . "INSERT") (66 . 1) (2 . "X-TEST")))) ; Select all "X-TEST" blocks with attributes
(if (not ss)
(princ "\nNo 'X-TEST' blocks found in the current layout.")
(progn
(setq insPt (getpoint "\nChoose the initial point to insert the blocks: ")) ; Insertion point
(foreach blk (mapcar 'cadr (ssnamex ss))
(setq blkRef (vlax-ename->vla-object blk)) ; Converts entity to VLA-Object
; Gets all the attributes of the block
(setq atts (vlax-invoke blkRef 'GetAttributes))
(foreach att atts
(if (= (strcase (vla-get-tagstring att)) "TAG")
(setq tagValue (vla-get-textstring att))
; Inserts a new "X-TEST" block at the specified point
(setq newBlkRef (vla-insertblock (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point insPt) "X-TEST" 1 1 1 0))
; Assigns the value of the "TAG" attribute to the new block
(setq atts (vlax-invoke newBlkRef 'GetAttributes))
(foreach att atts
(vla-put-textstring att tagValue)
; Moves the insertion point downward
(setq insPt (list (car insPt) (- (cadr insPt) 0.375) (caddr insPt)))
(princ)
I've tried several ways and I can't do it, I would like it to eliminate duplicate values and put the TAG parameter in alphabetical order.
Could anyone please help with this? I've been with no way out for days
