sort dynamic blocks
sort dynamic blocks
renanemeyer
sort dynamic blocks
renanemeyer
Hello everyone on the forum.
I have this lisp that reads all blocks with the name X-TEST.
Then it places each block found under the other, according to the value of the TAG parameter.
(defun c:TEST ( / ss blkRef insPt atts att tagValue newBlkRef )
  (vl-load-com)
  (setq ss (ssget "X" '((0 . "INSERT") (66 . 1) (2 . "X-TEST")))) ; Select all "X-TEST" blocks with attributes
  (if (not ss)
    (princ "\nNo 'X-TEST' blocks found in the current layout.")
    (progn
      (setq insPt (getpoint "\nChoose the initial point to insert the blocks: ")) ; Insertion point
      (foreach blk (mapcar 'cadr (ssnamex ss))
        (setq blkRef (vlax-ename->vla-object blk)) ; Converts entity to VLA-Object
        ; Gets all the attributes of the block
        (setq atts (vlax-invoke blkRef 'GetAttributes))
        (foreach att atts
          (if (= (strcase (vla-get-tagstring att)) "TAG")
            (setq tagValue (vla-get-textstring att))
        ; Inserts a new "X-TEST" block at the specified point
        (setq newBlkRef (vla-insertblock (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point insPt) "X-TEST" 1 1 1 0))
        ; Assigns the value of the "TAG" attribute to the new block
        (setq atts (vlax-invoke newBlkRef 'GetAttributes))
        (foreach att atts
            (vla-put-textstring att tagValue)
        ; Moves the insertion point downward
        (setq insPt (list (car insPt) (- (cadr insPt) 0.375) (caddr insPt)))
  (princ)
I've tried several ways and I can't do it, I would like it to eliminate duplicate values and put the TAG parameter in alphabetical order.
Could anyone please help with this? I've been with no way out for days
ВeekeeCZ
Your dwg drawing does not contain any DYNAMIC blocks. Also your code can't work with dynamic blocks. So... do you need to work with dynamic blocks?
Also would you post another dwg with the desired result?
renanemeyer
@ВeekeeCZ Thank you for your feedback and willingness to look into this. Sorry for the confusion, they are not dynamic blocks, they are just blocks (with attributes)
Below is a dwg with the blocks to be analyzed, the result that the current lisp produces and how it should be done
ВeekeeCZ
Possibly like this
(defun c:TEST ( / ss blkRef insPt atts att tagValue newBlkRef uniqueTags)
  (vl-load-com)
  (if (not ss)
    (progn
	(setq tagValue nil
	(foreach att atts
	    (setq tagValue (vla-get-textstring att))))
	(if tagValue
	  (if (not (vl-position tagValue uniqueTags))
	    (setq uniqueTags (cons tagValue uniqueTags)))))))
  (if uniqueTags
    (progn
      (setq uniqueTags (vl-sort uniqueTags '(lambda (s1 s2) (< (atoi (substr s1 2)) (atoi (substr s2 2)))))  ;; sort by numbers
	    uniqueTags (vl-sort uniqueTags '(lambda (s1 s2) (< (substr s1 1 1) (substr s2 1 1)))))           ;; sort by initial strings
      (foreach tagValue uniqueTags
	(foreach att atts
  (princ)
renanemeyer
@ВeekeeCZ you are incredible, you solved the problem that was giving me a headache for days. Thank you very much
ВeekeeCZ
Glad to help. Take the updated code -- new uniqueTags variable must be localized (or reset).
