VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Failed to load project from the file
5 REPLIES 5
armando4
299 Views, 5 Replies
When I try to load a DVB file, the message appears...
I have already uninstalled and installed again and the same error occurs... Anybody can help me?
AutoCAD 2025
5 REPLIES 5
Ed.Jobe
in reply to: armando4
You probably have a compile error. If you zip the dvb, you can post it here and I'll take a look at it.
Ed
How to post your code.
armando4
I think it doesn´t depend on the file due to the fact that my coleagues use the same file and it works. I tried to attach the file and it says that DVB file is not supported...
Ed.Jobe
That's why I told you to zip it.
Ed
armando4
in reply to: Ed.Jobe
Ops, of course. Attached.
norman.yuan
I have no problem loading the *.dvb file (Acad2024), either using command "VBALOAD", or "VBAMAN", or even simply drag the DVB file and drop into Acad's editor.
Norman Yuan
Drive CAD With Code
Forma Design Contest
AutoCAD Beta
