what the?
what the?
不适用
516 次查看
2 条回复
1 条消息(共 3 条)
what the?
不适用
Hi all.
Yesterday afternoon I used VBA to create a user form through AutoCAD's VBAIDE.
When I went to save it, it defaulted to a DVB file format. This morning when I went to open it back up to continue my work, it did not recognize the file format, and upon inserting it into the AutoCAD VBA, it inserted it as a module, and the code looks incredibly scwewy.
How do I open a dvb file in AutoCAD's VBAIDE?
I was expecting it to be like Excel's VBAIDE, but it did not work that way. It's like AutoCAD IDE doesn't recognize it's own file structure, so I must be doing something wrong here.
Furthermore, How do I save a user form to make sure it comes back up, without any trouble, when I need to edit it some more?
 ok, apparently dvb file formats are not approved file extension-attachments. So, I've attached it, but as a txt file. sigh........
TYIA.
0 个赞
已接受的解答 (1)
517 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
Ed__Jobe
已接受的解答
You don't use the IDE's file menu. You first have to load the dvb in acad using the VBAMAN command.
Ed
How to post your code.
3 条消息(共 3 条)
不适用
Hi.
Ok, I see it now.
Thank you.
0 个赞
