VBA FORM, EXPANDING FORM SIZE, BASED ON VISIBILITY OF FRAME
Good morning all.
I've built a user form in vba, and was wanting to have the form's overall size change, based on the visibility of frames which I'm placing on the form.
I.e., if I select a check box, an expanded version of the form is turned on, allowing secondary, and tertiary elements to be shown. However, when the base elements are active, I want the form to be a smaller/base size.
Is this possible?
TYIA
norman.yuan
You can change UserForm's size (Height/Width), Location(Left/Top) as needed in code.
Here is a very simplified case: an UserForm with a CheckBox on it. When the CheckBox is checked by user, the form's width expand, unchecked - shrinks:
Option Explicit
Private Const mWidth As Integer = 400
Private Sub CheckBox1_Click()
    If CheckBox1.Value Then
        Me.width = mWidth * 2
    Else
        Me.width = mWidth
End Sub
Private Sub UserForm_Initialize()
    Me.width = mWidth
End Sub
So, you can place the secondary controls on the form expanded side, obviously.
Norman Yuan
Drive CAD With Code
Option Explicit
    Else
        Me.width = mWidth
End Sub
    Me.width = mWidth
End Sub
Good morning.
 It works EXACTLY as I need too.
 Yes, the expansion of more controls is my purpose. One discussion I'd read on the web was that I could house secondary/tertiary controls within frames, and then turn the respective frame's visibility state on and off, based on the checkbox. But as I began working through it, I realized that I'd need to keep a constant width form. It made far more sense to change the width of the form as the need expanded. So.... this is a perfect answer to the frame/width issue.
Suuuwwwweeeet!
Thank you.
