VBA routine (sub or function) to insert text into a drawing file, referenced from a point
lgabrielRB55F
lgabrielRB55F
I have written the following VBA code to insert text into a drawing referenced from a point, which works fine.
Inspt = ThisDrawing.Utility.PolarPoint(Spt, 0.785398, 10.3337)
Set TextObj = ThisDrawing.PaperSpace.AddText(pbkw, Inspt, 0.05)
TextObj.Alignment = acAlignmentCenter
TextObj.TextAlignmentPoint = Inspt
What I want is to create a routine (sub or function) that handles the above, by passing all the necessary arguments as follows:
InsText(startpoint,radians,distance,textstring,height,txtalignment)
I have tried several iterations and I cannot get anything to work. My main issue is incorrect references. I know someone has already written this and would appreciate any and all assistance in this matter.
almutaz_86
I suppose this code will work:
Function InsText(Start_P_X As Double, Start_P_Y As Double, Rad As Double, Distance As Double, Txt_String As String, Height As Double, Txt_Align As AcAlignment) As AcadText
    Dim Insert_Point As Variant, My_Txt As AcadText, Start_Point(0 To 2) As Double
    Start_Point(0) = Start_P_X: Start_Point(1) = Start_P_Y: Start_Point(2) = 0
    Insert_Point = ThisDrawing.Utility.PolarPoint(Start_Point, Rad, Distance)
    Set My_Txt = ThisDrawing.ModelSpace.AddText(Txt_String, Insert_Point, Height)
    My_Txt.Alignment = Txt_Align
    My_Txt.TextAlignmentPoint = Insert_Point
    Set InsText = My_Txt
End Function
calling :
Sub Calling_Test()
    InsText 1.23, 4.56, 1, 5, "Hi", 5, acAlignmentBottomRight
    ZoomAll
End Sub
Ed__Jobe
You may want to change from ModelSpace to ActiveSpace like this.
    If ThisDrawing.ActiveSpace = acModelSpace Then
    Else
      Set My_Txt = ThisDrawing.PaperSpace.AddText(Txt_String, Insert_Point, Height)
    EndIf
End Function
Ed
How to post your code.
lgabrielRB55F
Thank you. Works perfectly. Now I can replace 7 lines of code with one for every text I insert into the drawing
