JS as additional language for ACad macroing etc
reymart.laranjo
reymart.laranjo
Is it possible to integrate JavaScript into AutoCAD? It's a versatile language with potential applications.
thank you and kind regards,
norman.yuan
There has been JavaScript API for AutoCAD (since AutoCAD 2015?), and it is now in its version 4. You can find its documentation here:
https://help.autodesk.com/view/OARX/2025/ENU/?guid=adsk_jsdev_autocad_javascript_api_about
However, when Autodesk released the JavaScrcipt API then, it probably aimed at preparing for moving AutoCAD to the web. In reality, AutoCAD still remains as one of the most local resource demanding desktop app so far and will be in that way for years to come, its JavaScript API most ends up collecting dust in its corner and rarely any CAD application developers want to waste time to try it. Even with current Autodesk's effort to provide web version of AutoCAD, with latest web technologies, they probably would not use the JavaScript API.
IMO, the AutoCAD's JavaScript API is basically useless, so far.
Norman Yuan
Drive CAD With Code
Ed__Jobe
In addition to what @norman.yuan said, if you are looking for a language other than C#, you might take a look at python. @daniel_cadext has developed a python wrapper for AutoCAD. Search the .NET forum for some links.
Ed
How to post your code.
reymart.laranjo
I just like JS due to i was a backend web developer who primarily uses JS as my main Lang. But i might stick to C# or VBA instead.
Thank you for your good insight!
reymart.laranjo
Thanks for this i didn't know someone developed a wrapper so that others could use python.
Will look into it.
