VBA Macro AutoCAD : DWG to PDF
Message 1 of 22
I have to create a VBA macro for AutoCAD, but I'm not a VBA expert... Smiley LOL
The goal of my macro is :
  1. Get all the DWG in a specific directory
  2. Open DWG
  3. Convert them to PDF
  4. Rename & Move the PDF to another specific directory
  5. Close the DWG
  6. Loop on the next DWG File
Actually, there is what my macro does :
  2. Open DWG (only the first)
I have to main issue :
  • I don't know how to close my DWG
  • The macro crash at the conversion part at the 2nd DWG
The macro :
Sub DWGtoPDF()
Dim file As String
Dim path As String
Dim destinationPath As String
path = "D:\Users\merel.thomas\Documents\test\dwg\"
destinationPath = "D:\Users\merel.thomas\Documents\test\pdf\"
'Get all DWG from directory
file = dir$(path & "*.DWG")
'Loop on all DWG files
While file <> ""
ThisDrawing.Application.Documents.Open path & file
Dim currentplot As AcadPlot
Set currentplot = ThisDrawing.Plot
ThisDrawing.ActiveLayout.ConfigName = "DWG To PDF.pc3" 'Plot device
ThisDrawing.ActiveLayout.CanonicalMediaName = "ANSI_full_bleed_D_(34.00_x_22.00_Inches)" 'PDF format
ThisDrawing.ActiveLayout.CenterPlot = True
ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
ThisDrawing.Application.ZoomExtents
'Convertion DWG to PDF
' FAIL HERE
currentplot.PlotToDevice
Dim splitedFileName() As String
Dim fileName As String
splitedFileName = Split(file, ".")
fileName = splitedFileName(0)
Dim originalPdfFile As String
Dim destinationPdfFile As String
originalPdfFile = path & fileName & "-Model.pdf"
destinationPdfFile = destinationPath & fileName & ".pdf"
Line1:
g_sb_Delay 26 'Waiting until the PDF is created
If dir(originalPdfFile) <> "" Then
'Move + rename PDF file
Name originalPdfFile As destinationPdfFile
Else
GoTo Line1 'If PDF is not created after x seconds, retry
End If
'Close file
' FAIL HERE
AcadApplication.Documents.Close
Wend
End Sub
Public Sub g_sb_Delay(ai_Count As Long)
Dim Start As Long
Dim I As Long
I = 0
Start = Timer ' Set start time.
Do While Timer < Start + ai_Count
DoEvents ' Yield to other processes.
Loop
End Sub
Can anyone help me ?
Replies (21)
Message 2 of 22
norman.yuan
Firstly, please use the "</>" button on top of the message text box to post code, so that the code is posted in read-able format.
Now regarding the errors you get:
1. Error on currentplot.PlotToDevice
The code should be:
currentplot.PlotToFile "[pdf file path/anme]"
because you are plotting to PDF file, right? So, you need to supply a desired file path/name here, not to rename the PDF file after plotting (you do not even know where the PDF file is!)
2. Error on AcadApplication.Documents.Close
AcadDocuments.Close() closes ALL drawings, not only the drawing you just opened for plotting.
3. Since the code needs to close each drawing after PDF plotting, you need to make sure the plotting is finished before the code in the "While...Wend" loop does the closing, thus, you need to disable background plotting. That is, you need to set system variable "BACKGROUNDPLOT" to 0 before your code does the plotting (and restore it back to its original value after the plotting is done. You do not use an empty "DO...Loop" to wait the background plotting to be finished.
To make the code a bit easier to read/debug, you might to organize it like this:
Public Sub DoPdfPlot()
    Dim backPlot As Integer
    backPlot=ThisDrawing.GetSysVariable("BACKGROUNDPLOT)
    ThisDrawing.SetSysVariable "BACKGROUNDPLOT", 0
    Dim fileNames() As String
    fileNames=GetFileNames("C:\....\dwgFolder")
    Dim fName as string
    Dim pdfName as string
    Dim dwg As AcadDocument
    Dim i As Integer
    For i = 0 to Ubound(fileNames)
        fName=fileNames(i)
        pdfName=    ''Determine PDF name based on DWG file name
        set dwg = AcadApplication.Documents.Open(fName)
        PlotToPdf dwg, pdfName
        dwg.Close false
    Next
    ThisDrawing.SetSysVariable "BACKGROUNDPLOT" baclPlot
End Sub
Private Function GetFileNames(path As String) As String()
    Dim fileName() As string
    Dim i As Integer
    Dim file As String
    file=Dir(path & "*.dwg")
    While file<>""
        ReDim Preserve fileNames(i)
       fileNames(i)=file
       i=i+1
       file = Dir
    Wend
    GetFileNames=fileNames
End Function
Private Sub PlotToPdg(dwg As AcadDocument, pdfFile As String)
    ''  do your plotting work here against the "dwg" object, including
    ''  set up correct layout as the active one, set up plot type: layout/extents/window, scale...
    '' Then eventually call AcadPlot.PlotToFile with "pdfFile" as parameter.
End Sub
The code is not tested, and is just meant to provide some ideas.
HTH
Norman Yuan
Drive CAD With Code
Message 3 of 22
Hi
Perfect, thanks a lot for the reply !
Sorry for the code block, i didn't see the button ^^
I use your solution and adapt it and it work perfectly
There is the final version of the macro for those who need it :
    ''Setting background plot variable
    backPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT")
    ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
    Dim oPath As String
    Dim dPath As String
    ''Original path -> Where DWG are
    oPath = "C:\...\dwg\"
    ''Destination path -> Where PDF go
    dPath = "C:\...\pdf\"
    fileNames = GetFileNames(oPath)
    Dim fName As String
    Dim pdfName As String
    Dim i As Integer
    For i = 0 To UBound(fileNames)
        fName = fileNames(i)
        Dim brutName As String
        ''Name de PDF "[DWGName].pdf"
        splitedFileName = Split(fName, ".")
        brutName = splitedFileName(0)
        pdfName = dPath & brutName & ".pdf" ''Determine PDF name based on DWG file name
        Set dwg = AcadApplication.Documents.Open(fName)
        dwg.Close False
    Next
    ThisDrawing.SetVariable "BACKGROUNDPLOT", backPlot
End Sub
    Dim i As Integer
    Dim file As String
    ''Get all DWG file from the Original Path
    file = Dir(path & "*.dwg")
    While file <> ""
        fileNames(i) = file
        i = i + 1
        file = Dir
    Wend
    GetFileNames = fileNames
End Function
Private Sub PlotToPdf(dwg As AcadDocument, pdfFile As String)
    Set currentplot = dwg.Plot
    ''Convertion step
    currentplot.PlotToFile pdfFile
End Sub
Message 4 of 22
maratovich
I do not think that this is final.
And what if you need to print everything in different formats?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 5 of 22
You can change
And
easily, so, just add some parameters to the PlotToPdf function, but actually, i don't need it and i think i gonna need it in the future...
But i have another request that I don't know know how to do this :
I need to write another macro for :
  1. Open AutoCAD
  2. Launch this macro (Project.dvb)
  3. Close AutoCAD
  4. Close AcrobatReader
I don't know if i should use Batch, VBA or Lisp and i don't know how to do it...
Message 6 of 22
Can you  give me a vba macro programming to convert pdf to dwg ??
Message 7 of 22
Can you please write for me a vba macro fpr converting pdf to dwg ???
Thanks in advance
Message 8 of 22
maratovich
No problems :
www.kdmsoft.net
Message 9 of 22
Thanks in advance !!
Message 10 of 22
maratovich
Did you watch the video in the previous post ?
www.kdmsoft.net
Message 11 of 22
Cool !
Message 12 of 22
Hi !
How is the PDF to DWG macro coming up ???
Thanks in advance
Message 13 of 22
HI,
I am new to AutoCAD and Macros, I have tried your code but it stuck at below line saying drawing not found, however drawing is present in the directory.
Please help me in this regards, this error is not making any sense to me.
Message 14 of 22
Ed__Jobe
Show your code.
Ed
How to post your code.
Message 15 of 22
Private Sub rename_Click()
Dim oPath As String
Dim dPath As String
oPath = "C:\Documents and Settings\Administrator\Desktop\New Folder\"
dPath = "C:\Documents and Settings\Administrator\Desktop\PDF\"
Dim fName As String
Dim i As Integer
'Set dwg = AcadApplication.Documents.Open(fName)
dwg.Close False
Next
End Sub
Dim i As Integer
Dim file As String
While file <> ""
fileNames(i) = file
i = i + 1
file = Dir
Wend
End Function
''Convertion step
End Sub
In opath and dpath if remove the last backslash(\) of directory the code gives an error at For i = 0 To UBound(fileNames) stating "subscript out of range" if I put backslash it stuck at Set dwg = AcadApplication.Documents.Open(fName) saying file not found even though the error has file name which is present in the directory.
I tried to comment Set dwg = AcadApplication.Documents.Open(fName)  the code shows error at ThisDrawing.ActiveLayout.CanonicalMediaName = "ANSI_full_bleed_D_(34.00_x_22.00_Inches)"  stating invalid input.
I am using autocad 2008.
Message 16 of 22
Ed__Jobe
If there aren't any files, you will get the 'out of range' error on this line: For i = 0 To UBound(fileNames), when the UBound function fails. Typically, users don't have access to the "Documents and Settings" folder. Try using C:\Users\Public\Documents\Dwg\ instead.
Ed
Message 17 of 22
Hi Ed,
Sorry for delay response.
I tried your suggestion by creating PDF and DWG folder in C drive; like C:\PDF\ and C:\DWG\ but the problem is same. it gives the error that dwg file is not found at
Message 18 of 22
Ed__Jobe
The problem is not with the code. Obviously, it can't find it where you put the files. In Windows 10, rights are restricted in C:\ as well. Either that or you misspelled something. Try putting the files where you are positive users have rights to. That's why I suggested the Public profile. Try the pat I gave you before you assume something is wrong with the code. You can also use a network share which provides the necessary rights.
Ed
Message 19 of 22
wianeh6700
What if want to use a window so select the extent, Any Ideas please? can i create a layer that specifies the my extent
Message 20 of 22
Ed__Jobe
See this topic. You can't create a layer to specify what to plot, but you can create a named View. Then you can assign the view to the current page setup.
BTW, your post has nothing to do with this thread. You should have started a new thread.
Ed
