Hello
I have a dynamic block. This block is constructed from a closed polyline, and a number of other small blocks. The dynamic block uses only the flip parameter. The other smaller blocks have a one letter text string as part of the block. The string is constant, that is not an attribute. When the block is flipped, the text strings are reversed in the small blocks. You can see this in the 2 attached jpegs. I have also attached the dwg file. I am using Autocad C3D as AutoCad 2016. I have spent the last 2 days trying to solve this problem, but to no avail.
Thank very much
John
