USING VBA with DesignCenter find all layouts in a given dwt, preferably with ACAD ie Interop
QNashJSRL8
QNashJSRL8
I want to be able to use VBA to navigate withing DESIGNCENTER to locate a specific dwt then view all of the layout tabs that are associated with that specific dwt.
I know I can open a specific path in designcenter with the following
acadDoc.SendCommand("adcnavigate" & vbCr & dwtTemplateLocations & vbCr)
ie opens DESIGNCENTER to where my templates are. In there I could navigate to my specific dwt and expand it to view its info. (Blocks, layers, layouts, etc)
Would anyone know a way I could get to this info strictly through VBA with something like
NOTE this part is made up but would something like this be possible
SomeObject like AcadDesignCenter dsObject
dsobject.SomeProperty  That lets me view the files at a location
.Something that lets me view the designCenter info associated with the dwt at said location
I want to be able to find the above info without strictly opening the said template.
norman.yuan
You can use ObjectDBX to read/open (in memory, not visually in AutoCAD editor) a drawing file (*.dwg, or *.dwt), and collect the information (layers, blocks, DimStyles...) that are available vis Design Center.
Search this forum for "ObjectDBX" for code example of how to open drawing file with ObjectDBX.
Norman Yuan
Drive CAD With Code
QNashJSRL8
Thank you for pointing me into ObjectDbx.
doc = acadApp.GetInterfaceObject("ObjectDBX.AxDbDocument.24")
doc.Open(dbxFilePath)
For Each test As Object In doc.Layouts
            Dim name As String = test.Name
        Next
Just on some testing now, as of now I found that *.dwg will work and you can access the layouts, but when I use my *.dwt. I cannot access the layouts
doc.Layouts.count is 2
item(0) being Nothing
item(1) being the model space
I would expect it to also give me the other layout tabs, but it does not.
Here is some info I found about dwt issues
Insert Layout from various Templates (augi.com)
I am confident there is a work around to this, it wouldn't make sense to me that dwt info is limited.
If anyone knows anything about this let me know. I will post a solution if I find one.
Ed__Jobe
ObjectDbx STILL can't open a dwt. However, a template is just a dwg with a different extension. You can temporarily save the dwt as a dwg, open it, do your stuff, and then delete the temp file. I created a class that automatically handles this case in the xOpen method. The attached zip file is an updated version of the one I posted at AUGI.
Ed
How to post your code.
