Accessing the vertices of an offset line
grenee
Observer Observer
grenee
Observer
Observer
Good day.
I am trying to access the vertices of an offset line. There is no success after intense tries. Can anyone help please?
Here is the code.
The problem is at line 30.
The message is : Object required : Runtime error 424
Private Sub CommandButton10_Click()
Dim Coord1(1) As Double
Dim Coord2(1) As Double
Dim LineObj As AcadLine
Coord1(0) = Me.TextBox1: Coord1(1) = Me.TextBox6
Coord2(0) = Me.TextBox5: Coord2(1) = Me.TextBox4
DrawlineGivenTwoVertices Coord1, Coord2, LineObj
Dim OffsetLinePoints As Variant
Dim OffsetLine As Variant
     OffsetLinePoints = LineObj.Offset(20)
     Set OffsetLine = OffsetLinePoints(0)
     OffsetLine.Color = acGreen
     OffsetLine.Update
     Dim NumVertices As Integer
        Dim ReturnedObj() As Double
        Dim vertex1(1) As Double
        Dim Vertex2(1) As Double
              ReturnedObj = OffsetLinePoints.Coordinates
              vertex1(0) = ReturnedObj(0)
              vertex1(1) = ReturnedObj(1)
              NumVertices = UBound(ReturnedObj)
              Vertex2(0) = ReturnedObj(NumVertices)
              Vertex2(1) = ReturnedObj(NumVertices)
       Dim StraightPline As AcadLWPolyline
      DrawPlineGiven2Vertices vertex1, Vertex2, StraightPline
End Sub
*Moderator edit* changed programming language to Visual Basic.
Ed__Jobe
You have several problems that would be evident if you did some debugging. Set a breakpoint near the beginning of the code, e.g. line 7. Then start debugging with F5. When the execution stops at line 7, examine the status of variables in the Locals Window (View>Locals Window). If their value is what you expect, hit F8 and examine the next set of variables. Keep doing this until you find a problem.
In your case, here are some problems to look for:\
  1. Line 14, 15: The offset method doesn't return points. It returns an array of entities.
  2. Line 23: ReturnedObj should be a variant because it needs to accept an array from the Coordinates method.
  3. Lin3 29. A Line object doesn't have a Coordinates method, just StartPoint and EndPoint properties. Each of those hold a two-element Double array for x and y.
  4. Line 35: A line always has only 2 vertices.
  5. Line 41: You will want to delete OffsetLine since you are replacing it with a pline.
     'Dim NumVertices As Integer    'not applicable
        'Dim ReturnedObj As Variant 'Not needed
        'Dim vertex1(1) As Double   'Not needed
        'Dim Vertex2(1) As Double   'Not needed
              'ReturnedObj = OffsetLinePoints.Coordinates 'invalid call
              'vertex1(0) = ReturnedObj(0)
              'vertex1(1) = ReturnedObj(1)
              'NumVertices = UBound(ReturnedObj)
              'Vertex2(0) = ReturnedObj(NumVertices)
              'Vertex2(1) = ReturnedObj(NumVertices)
      DrawPlineGiven2Vertices OffsetLine.StartPoint, OffsetLine.EndPoint, StraightPline
      OffsetLine.Delete
Ed
How to post your code.
grenee
Observer
Observer
Thanks for the assistance, Ed. Jobe.
But there still appears to be a problem with getting the "offsetLine" created.
This is my new code. But it still does not work. Can you see an error in it?
The error message is at line 21. The message highlights: .Startpoint.
The message is: Type mismatched. Arrary user-defined type expected
      DrawPlineGiven2Vertices OffsetLine.StartPoint, OffsetLine.Endpoint, StraightPline
      OffsetLine.Delete
End Sub
Ed__Jobe
StartPoint, EndPoint are 3D array of double. You either have to convert them to the data type your custom function requires or change your custom function to take point arrays.
Type: Variant (three-element array of doubles)
A 3D coordinate representing the start point of the object.
Ed
