Plot.PlotToDevice() random failure
Markeckert
Message 1 of 18
Markeckert
I'm using the Plot.PlotToDevice() function in a VB application in conjunction with AutoCAD 2021. My results are inconsistent. It randomly drops pages from the output PDF file and cuts off sections of other pages. Does anyone know how to resolve this?
Replies (17)
Message 2 of 18
Ed__Jobe
You need to show your code if you want help with it. My first thought is that there are problems with your page setup for the problem sheets. You might also check this forum. I recently helped a couple others with publishing to pdf.
Ed
How to post your code.
Message 3 of 18
Markeckert
Here's a little more detail. The VB app uses this line of code to write a DWG file into a PDF file - Plotresult = bb.Plot.PlotToDevice(). Using the same set of DWG files I sometimes get a complete PDF file and other times the file will be blank or partially blank. I've checked the Plotresult integer I set up as a return value, and it always shows a -1 after execution of the statement regardless of whether it was successful or not.
Here is the routine. I highlighted the statement in Yellow.
Private Function Export(ByVal strOldFile As String) As Boolean
Dim strFile As String
Dim strFile2 As String
Dim strFile3 As String
Dim i As Integer
Dim dd As Autodesk.AutoCAD.Interop.Common.AcadPlotConfiguration
Dim aa As Autodesk.AutoCAD.Interop.AcadDocument
Try
Export = False
strFile = strNewFolder & "\tmp_Stage1_" & VB.Left(objAutocad.ActiveDocument.Name, Len(objAutocad.ActiveDocument.Name) - 4)
'objAutocad.Preferences.OpenSave.CreateBackup = False
System.Windows.Forms.Application.DoEvents()
Dim bb As Autodesk.AutoCAD.Interop.AcadDocument
bb = objAutocad.ActiveDocument
aa = objAutocad.Documents.Open(Label4.Text)
dd = aa.PlotConfigurations.Item("PDF")
'dd = objAutocad.ActiveDocument.PlotConfigurations.Item("PDF")
bb.Layouts.Item("Model").CopyFrom(dd)
strFile = bb.Name
Dim di As Date
di = Now
Do While DateDiff(DateInterval.Second, di, Now) < 2
Loop
Try
Catch ex As Exception
CreateLog(strLogFile, "Custom Error: " & ex.Message)
End Try
*Moderator edit* post your code using a code window.
Message 4 of 18
Ed__Jobe
You have to include the logic to return the result. In C# you need to use the Return statement. I'm not sure if its the same in VB. I don't remember. In VBA you use the Set statement and the name of the function.
Set Export = true
The best place for this logic would be in your try statement.
Ed
Message 5 of 18
Markeckert
Any thoughts on why the Plot.PlotToDevice() statement would be successful only randomly? I changed the VB code to execute the statement two times in a succession. It will sometimes produce the populated PDF on the first iteration and fail on the second or it will fail on the first iteration but be successful on the second one.
Message 6 of 18
Ed__Jobe
Without seeing all your code and having sample files to test on, I won't be able to reproduce your results. So my best guess is what I stated in post 2.
This looks like you want to plot from an out-of-process application. Am I correct? It might help if you stated what your goal is. Rather than plotting using AutoCAD, you might want to use AcCoreConsole.
Finally, you may want to consider moving from VB.NET to C#, since it's what all us AutoCAD developers use and you will find that almost all sample code is written in C#. You can still use the COM api with C#.
Ed
Message 7 of 18
norman.yuan
You may want to try to set "BACKGROUNDPLOT" system variable to 0 (i.e. disable back ground plotting) before calling PlotToDevice() (and restore it back afterwards).
But it would not solve the issue you stated in the original post regarding content not plotted corrected, which is determined by layout/PlotConfiguration identified by Item("PDF"), to which your code does nothing to change/adjust it, so I have to assume the layout's plot is not configured correctly.
Norman Yuan
Drive CAD With Code
Message 8 of 18
Markeckert
Are you able to provide the syntax to set the BACKGROUNDPLOT system variable or a link to the method to do so?
Message 9 of 18
Ed__Jobe
ThisDrawing.SetVariable. ThisDrawing.GetVariable
Dim bgp As Integer
bgp = ThisDrawing.GetVariable("BACKGROUNDPLOT")
ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
'continue process
ThisDrawing.SetVariable "BACKGROUNDPLOT", bgp
Ed
Message 10 of 18
Markeckert
Setting the BACKGROUNDPLOT to 0 didn't change the outcome. I'm still getting random blank pdfs and it doesn't seem to be throwing an error. Is there any other error checking that you can suggest?
Message 11 of 18
norman.yuan
Getting blank page is because the layout/PlotConfiguration is the plot content (view/window/layout size) larger than the paper size used in plotting.
So, basically, you need to open the drawing, manually use the existing plot settings to plot to PDF to verify the layout/PlotConfiguration is set correctly. However, if you are familiar with Layout/Plotting setup, you can easily spot these issues in the plotting dialog box (and fix it there). It is really not a programming/code issue, because your code simply plot whatever the layout/PlotConfiguration was set.
Norman Yuan
Drive CAD With Code
Message 12 of 18
Ed__Jobe
Maybe if you answered my questions in post 6.
Ed
Message 13 of 18
Markeckert
The blank pages are random and are from the same input drawing files. If I run the process several times using the same input drawings files, I'll get different results almost every time. On some runs I get all the pages populated and on other runs page one is blank and on others page 3 is blank. I can't find any errors thrown to indicate what is happening.
Message 14 of 18
Markeckert
The VB app that I'm struggling with is not new development. It's been used for several years and it was working with the AutoCAD 2018 product. Its when I switched to AutoCAD 2021 that it began to have this problem of dropping pages randomly for the same input files. Once in a while it will process and combine all of the input files but most of the time it will create one or two blank pages in the output PDF. I have not been able to trap any error codes.
Message 15 of 18
Ed__Jobe
I'm sorry, but you didn't answer my questions. The code you shown is seems to be lacking. It doesn't matter how long you've been using it if there is a better way of doing it. I would rewrite it but I don't have enough info to make any recommendations.
Ed
Message 16 of 18
Markeckert
I'm attaching some of the code. I didn't include it all since it might be a bit much to sort through especially if it doesn't apply to the issue. The CreatePDF(bb, 1) subroutine is what is failing to consistently write out a full PDF page.
Dim i As Integer
Try
Export = False
strFile = bb.Name
'Dim di As Date
'di = Now
'Do While DateDiff(DateInterval.Second, di, Now) < 2
' Application.DoEvents()
'Loop
Dim Plotresult As Integer
' SetAttr(BACKGROUNDPLOT = 1)
CreatePDF(bb, 1)
Try
blnHasErrors = True
End Try
Do While Dir(Label7.Text & strFile.Substring(0, strFile.Length - 4) & "*.pdf") = ""
Loop
strFile3 = Dir(Label7.Text & strFile.Substring(0, strFile.Length - 4) & "*.pdf")
strFile2 = strNewFolder & "\tmp_Stage1_" & strFile.Substring(0, strFile.Length - 4)
Thread.Sleep(3000)
System.IO.File.Move(Label7.Text & strFile3, strFile2 & ".pdf")
'Rename(Label7.Text & strFile3, strFile2 & ".pdf")
'Rename(Label7.Text & strFile.Substring(0, strFile.Length - 4) & " Model (1).pdf", strFile2 & ".pdf")
UpdatePDF(strFile2 & ".pdf")
Export = True
Try
bb.Close(False)
End Try
blnHasErrors = True
lblCurrentFile.ForeColor = Color.Red
CreateLog(strLogFile, "Export: Error Exporting File: (" & strOldFile & ") - " & ex.Message)
End Try
Try
aa.Close(False)
CreateLog(strLogFile, "Export: Closing ACAD: (" & strOldFile & ") - " & ex.Message)
End Try
Try
dd = Nothing
End Try
GC.Collect(1)
End Function
Private Sub CreatePDF(ByVal bb As Autodesk.AutoCAD.Interop.AcadDocument, ByVal PlotResult As Integer)
Dim backPlot As Integer
backPlot = objAutocad.ActiveDocument.GetVariable("BACKGROUNDPLOT")
Try
objAutocad.ActiveDocument.SetVariable("BACKGROUNDPLOT", 0)
PlotResult = bb.Plot.PlotToDevice()
End Try
End Sub
Message 17 of 18
Markeckert
I just noticed that some of the code I pasted was cut off so I have attached a file with the code.
Message 18 of 18
Markeckert
I added the code to the posting. Hopefully that will be of some help. This Application worked well and still does with AutoCAD 2018. Does anyone have an idea what might be different in AutoCAD 2021 that would cause the issue that I'm experiencing ? If there was just a method to trap the error I could put a retry in the code.
