Union of two Regions
Dear All,
How do I do a boolean Union of two co-planar regions with AutoCAD VBA? (see regionobjrev and regionobjrev2 created with the example code below)
TIA
Bernardo Botelho
'Creates two diferent regionsN
Sub TesteRegion()
    Dim plineObj As AcadLWPolyline
    Dim plineObj2 As AcadLWPolyline
    Dim points(0 To 9) As Double
        points(0) = 0: points(1) = 0
        points(2) = -5: points(3) = 0
        points(4) = -5: points(5) = -3
        points(6) = -8: points(7) = -9
        points(8) = 0: points(9) = 0
        Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    Dim Explodeobjrev As Variant
        Explodeobjrev = plineObj.Explode
    Dim regionobjrev As Variant
        regionobjrev = ThisDrawing.ModelSpace.AddRegion(Explodeobjrev)
    Dim points2(0 To 9) As Double
        points2(0) = -1: points2(1) = -1
        points2(2) = 5: points2(3) = 0
        points2(4) = 5: points2(5) = 3
        points2(6) = 8: points2(7) = 9
        points2(8) = -1: points2(9) = -1
        Set plineObj2 = ThisDrawing.ModelSpace.AddLightWeightPolyline(points2)
    Dim Explodeobjrev2 As Variant
        Explodeobjrev2 = plineObj2.Explode
    Dim regionobjrev2 As Variant
        regionobjrev2 = ThisDrawing.ModelSpace.AddRegion(Explodeobjrev2)
End Sub
Alfred.NESWADBA
add this line as the last line before "End Sub":
      Call regionobjrev(0).Boolean(acUnion, regionobjrev2(0))
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Alfred,
Thank you very much for your quick reply, that worked very well.
(As you problably noticed, I´m a VBA newbie.)
Best Regards
Bernardo
Dear Alfred,
Now I´m stuck with the problem of editing the region I created (change simbology, move, delete, etc)
How do I identify that region in VBA?
Bernardo
Hallex
If this actual for you, see if the following addition is working for you:
Option Explicit
Sub TesteRegion()
Dim i As Integer
'regionobjrev(0) would be as result of boolean operation:
regionobjrev(0).Boolean acUnion, regionobjrev2(0)
'if you want just rich at common properties then cast an entity from variant:
Dim ent As AcadEntity
Set ent = regionobjrev(0)
ent.color = acCyan
'to get/put region's properties you have to cast Region from entity (or from variant same as above)
Dim reg As AcadRegion
Set reg = ent
'dispaly info if it's needs
MsgBox "Area of Region:" & vbCr & Round(reg.Area, 2) & " sq.units" & vbCr & _
"Centroid of Region:" & vbCr & Round(reg.Centroid(0), 3) & " ; " & Round(reg.Centroid(1), 3), vbInformation
Dim expEnt As AcadEntity
For i = 0 To UBound(Explodeobjrev2)
Set expEnt = Explodeobjrev2(i)
expEnt.Delete
Next
For i = 0 To UBound(Explodeobjrev)
Set expEnt = Explodeobjrev(i)
expEnt.Delete
Next
plineObj2.Delete
plineObj.Delete
End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
