Mullileader how to change TextHeight
Please write a code how to change a text height "123"
I can't do this and find a sample.
I found that code in help for autocad , I added dogleg direction
Sub Example_Blockttribute()
' This example creates an MLeader object and gets and sets values for
' the block attribute type.
Dim vector(2) As Double
vector(0) = 1
Dim points(0 To 5) As Double
points(0) = 0: points(1) = 4: points(2) = 0
points(3) = 1.5: points(4) = 5: points(5) = 0
Dim i As Long
Dim oML As AcadMLeader
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
    oML.ContentType = acBlockContent
 '   oML.ContentBlockType = acBlockBox
  oML.ContentBlockType = acBlockCircle
  oML.SetDoglegDirection 0, vector
   oML.DogLegged = True
   oML.DoglegLength = 3
oML.ArrowheadSize = 0.3
Dim sBlock As String
    sBlock = oML.ContentBlockName
Dim o As AcadEntity
For Each o In ThisDrawing.Blocks(sBlock)
    If o.ObjectName = "AcDbAttributeDefinition" Then
Call oML.SetBlockAttributeValue(o.ObjectID, "123")
 '   MsgBox oML.GetBlockAttributeValue(o.ObjectID)
Next o
    Update
    ZoomExtents
End Sub
Alfred.NESWADBA
could that be the solution for you?
oML.BlockScale = 5
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I checked ,it works :
Thank You for help
   oML.ScaleFactor = 5
Next o
 I would like to find out :
How  to change a text Height  (and other factors) inside a block attribute
