Block with attribute vba
calteq
calteq
Having a problem justifying the text of an attribute created in vb ...
here's an simple example ..
Sub BlkAttribute()
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    Dim txtstyle As AcadTextStyle
    Dim Pnts(0 To 9) As Double
    insertionPnt(0) = 0
    insertionPnt(1) = 5
    insertionPnt(2) = 0
    Set blockObj = ThisDrawing.Blocks.Add _
                     (insertionPnt, "BlockWithAttribute")
    Pnts(0) = -7.5: Pnts(1) = 5
    Pnts(2) = -7.5: Pnts(3) = 10
    Pnts(4) = 7.5: Pnts(5) = 10
    Pnts(6) = 7.5: Pnts(7) = 5
    Pnts(8) = -7.5: Pnts(9) = 5
    ' Create a lightweight Polyline object in model space
    Set plineObj = blockObj.AddLightWeightPolyline(Pnts)
    ' Add an attribute to the block
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 3.5
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 0
    insertionPoint(1) = 7.5
    insertionPoint(2) = 0
    tag = "New Tag"
    value = "New Value"
    Set attributeObj = blockObj.AddAttribute(height, mode, _
                          prompt, insertionPoint, tag, value)
    'attributeObj.Alignment = acAlignmentBottomCenter
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock _
               (insertionPnt, "BlockWithAttribute", 1#, 1#, 1#, 0)
End Sub
the attribute is created with a 'left' justification.
when the hi lited part of the code is used the attributes insertion point is changed to 0,0
Any suggestions!!!!
Regards
Geoff
arcticad
It's a known bug. You will need to move the attributes insertion point back to the known location after you change the justification.
(defun botsbuildbots() (botsbuildbots))
calteq
Thx arcticad
probably an easy solution for the more knowledgable ....
Have trawled thro many web pages to no avail!
Have tried this after the alignment statement ....
    attributeObj.Move (origin,insertionPoint) .... get 'syntax error'
    attributeObj.Move(origin,insertionPoint)  ... get 'complie error' expected '='
    attributeObj.Move = insertionPoint .....        get 'complie error'   'argument not optional'
something I'm not doing correctly ....
Hope you don't mind pointing me in the right direction.
Geoff
calteq
Thx arcticad
I've managed to do it ...
        attributeObj.Move Origin, CtrPnt
Regards Geoff
