trying to creat 3dsolid using function
almutaz_86
almutaz_86
Good Evening
I'm trying to creat box from a function
I don't know what I missed here :
Sub drawbox()
Call pvc(test, 18, 3, 250, 0, 0, 0)
End Sub
Public Function pvc(pvcname As String, Length As Double, Width As Double, Height As Double, center0 As Double, center1 As Double, center2 As Double)
Dim center(0 To 2) As Double
center(0) = center0: center(1) = center1: center(2) = center2
Set pvcname = ThisDrawing.ModelSpace.AddBox(center, Length, Width, Height)
End Function
Ed__Jobe
You don't tell us what the problem is or what error you are getting. But I can see that your Call statement doesn't match the argument types. The way you have it, test is a variable name, not a string. Also, you do not use that argument in your function. It's unnecessary. Try:
Call pvc("test", 18, 3, 250, 0, 0, 0)
Or, eliminate the pvcname argument from your function.
Ed
How to post your code.
almutaz_86
Thanks @Ed__Jobe
there is a big mistake in that code:
public function pvc (pvcname As String,....)
pvcname should declared as acad3dsolid .
and its worked after I removed it from funcion arguments
Half solution is a good solution 🙂
