How to extract autocad table block cells to image
I want to extract blockcells
I extract textCells by AcadTable.GetCellValue(row, column)
but I don't know how to extract blockCell Image
Ed__Jobe
It's not an image of a block its an AcadBlockReference object. Is that what you want to get, or a raster image of the block?
Ed
How to post your code.
Ed__Jobe
Here's an example of how you might get the block definition of the table cell, where a table has a block inserted in the first cell.
Sub tableTest()
    Dim tb As AcadTable
    Dim c As LongPtr
    Dim pp As Variant
    ThisDrawing.Utility.getEntity tb, pp, "Select a table"
    c = tb.GetBlockTableRecordId(0, 0)
    Dim blk As AcadBlock
    For Each blk In ThisDrawing.Blocks
        If blk.ObjectID = c Then
            Debug.Print blk.Name
    Next
End Sub
Ed
Thank you for reply me
It's really helped me, but I want raster image of block. How can i do this??
norman.yuan
In short answer, no, you cannot do it with pure VBA.
Norman Yuan
Drive CAD With Code
