Attribute (AcadAttributeReference) can be rotated manually, or through code (VBA code included, of course). When you say "... link to action...", what does the action mean? A dynamic block's action? If that is what you mean, then you must have a dynamic block, that defines a rotation action, which applies to attribute(s), so that user can manually change the rotation parameter value to rotate the attribute(s). If this is your situation, then yes, you can also use code to change the rotation parameter to change the attribute rotation, as if user does it manually. The code would be like (psedo code)
Dim blk As AcadBlockReference
Set blk = ...Identify the block reference (selecting, or loop through Model/PaperSpace...)
Dim pro As AcadDynamicBlockReferenceProperty
Dim props As Varaint
Dim i As Inteter
Set props=blk.GetDynamicBlockProperties()
For i=0 To Ubound(props)
Set prop = props(i)
If UCase(prop.PropertyName) = "[MY ROTATION PARAMETER NAME]" Then
prop.Value=3.1415926/2 ' rotate 90 degree, assume the original rotation is 0
Exit For
Next
Again, attributes, like other AutoCAD entities, can be rotated by code (i.e. you do not have to mate the block dynamic).
