Text editor for .dvb?
Message 1 of 9
Hi all,
Does anybody know of a text editor capable of handling the code area of .dvb
files
The ability to cut & paste from multiple open files, without having to
create .bas file first would be fantastic.
Regards
Dave Fox
Replies (8)
Message 2 of 9
David,
You can cut from any Windows application (including Help files) and paste
them directly into the VBAIDE modules. You may also open as many DVB files
as you like and do the same thing. I not sure what you are referring to when
you would need to first paste the code into a .bas file first. Elaborate?
Joe Sutphin
Author of "AutoCAD 2000 VBA Programmers Reference"
ISBN #1861002564
Checkout Sources - The magazine dedicated to AutoCAD customization
http://vbdesign.hypermart.net/sources/
david fox wrote in message
news:874l1b$d5e22@adesknews2.autodesk.com...
> Hi all,
.dvb
> files
> Regards
> Dave Fox
Message 3 of 9
Textpad found at www.textpad.com is a great text editor for those type of
needs. It has syntax templates for vb, lisp, c, html, java and more. It
has foreign language modules and spell checkers. I can't praise it enough.
I've been a registered user since version 1.1, it' now at version 4.1. I've
only had to pay one upgrade of $10.00 in the last 4 of 5 years.
Volker
Volker Cocco
vcad@alaska.net
"david fox" wrote in message
> Hi all,
.dvb
> files
> Regards
> Dave Fox
Message 4 of 9
Joe Sutphin wrote in message
news:874o8h$d5f24@adesknews2.autodesk.com...
> David,
Really, can you explain how, 'cause I haven't got a clue how to open more
than one DVB file at time?
I wish to have 2 dvb files open at the same time so I can cut & paste
between them.
The only way around this, (as far as I know) is to export one of them to a
.bas file which seems to be ASCII compatible & therefore able to be loaded
into a text editor. That process is laborious.
How that clarifies my problem
Regards
Dave Fox
> Joe Sutphin
> ISBN #1861002564
> > Hi all,
> .dvb
> > files
> > Regards
> > Dave Fox
Message 5 of 9
In Autocad run vbaman and you can load as many as you want
Kent Keller
Strobe Data Inc.
www.strobedata.com
One good thing about being wrong
is the joy it brings to others.
news:87aaea$5d712@adesknews2.autodesk.com...
> > David,
paste
files
> between them.
> Regards
> Dave Fox
Elaborate?
> > Joe Sutphin
> > ISBN #1861002564
> > > Hi all,
of
> > .dvb
> > > files
> > > Regards
> > > Dave Fox
Message 6 of 9
Hi Volker
You're right, Textpad is a great text editor, but I'm not sure it can handle
the code within a .dvb file.
If you know of a way, could you let me know?
Regards
Dave Fox
Volker Cocco wrote in message
news:87531h$f9914@adesknews2.autodesk.com...
enough.
I've
Message 7 of 9
Is that an R15 command?
I'm (un)fortunately running R14
Regards
Dave Fox
Kent Keller wrote in message
news:87aain$5dv15@adesknews2.autodesk.com...
> Kent Keller
> Strobe Data Inc.
> www.strobedata.com
Message 8 of 9
Yes I think it is only a A2K command. If I remember right you may be out of
luck as I think R14 did only load one at a time.
Sorry
Kent Keller
Strobe Data Inc.
www.strobedata.com
news:87adi8$5d617@adesknews2.autodesk.com...
> Regards
> Dave Fox
Message 9 of 9
Hi David,
One way to do it is to open two sessions of AutoCAD, and load a different
project in the second session. You can then copy, cut, and paste between
the IDEs.
Hope this helps,
- Adam
news:87aedm$5d917@adesknews2.autodesk.com...
of
> Sorry
> Kent Keller
> Strobe Data Inc.
> www.strobedata.com
> > Regards
> > Dave Fox
