Open a HTM document from Autocad
Message 1 of 8
I am launching internet explorer from within cad but I do not know how to
open a specific URL once Internet explorer is up.
I tried:
Public Sub OpenIE()
Dim IE As Object 'IE application object
On Error Resume Next 'Get IE
Set IE = GetObject(, "InternetExplorer.Application") 'Get IE if Open
If Err <> 0 Then
Err.Clear
Set IE = CreateObject("InternetExplorer.Application") 'Launch IE
if not Open
If Err <> 0 Then
MsgBox "Could not load InternetExplorer.", vbExclamation
End
IE.Visible = True 'Bring IEto the front
I thought this would do it?!
IE.LocationURL = "c:\adt2.htm"
End Sub
Any comments would be greatly appreciated.
Michael LaQuire
Arthur Ruteberg Homes, Inc.
Cad Trainer
mlaquire@arhomes.com
Replies (7)
Message 2 of 8
Wow! That is a long way to go. Try this instead:
(command "browser" "c:\\adt2.htm")
Get free software and more at http://www2.stonemedia.com/~franko
"Michael LaQuire" wrote in message
news:874oni$csc31@adesknews2.autodesk.com...
> I tried:
> Public Sub OpenIE()
> If Err <> 0 Then
> Err.Clear
> if not Open
> If Err <> 0 Then
> End
> End If
> End If
> End Sub
> Michael LaQuire
> Cad Trainer
Message 3 of 8
Glad to help.
news:874pfo$d5p13@adesknews2.autodesk.com...
> Thanks Frank, Just what I needed. I did not know about the browser
command.
> Always learning.
> Michael LaQuire
> Cad Trainer
> Frank Oquendo wrote in message
> news:874p9g$d6j33@adesknews2.autodesk.com...
> to
> > > I tried:
> > > Public Sub OpenIE()
> Open
> > > If Err <> 0 Then
> > > Err.Clear
'Launch
> IE
> > > if not Open
> > > If Err <> 0 Then
> > > End
> > > End If
> > > End If
> > > End Sub
> > > Michael LaQuire
> > > Cad Trainer
Message 4 of 8
Thanks Frank, Just what I needed. I did not know about the browser command.
Always learning.
Michael LaQuire
Cad Trainer
to
> > I tried:
> > Public Sub OpenIE()
Open
> > If Err <> 0 Then
> > Err.Clear
IE
> > if not Open
> > If Err <> 0 Then
> > End
> > End If
> > End If
> > End Sub
> > Michael LaQuire
> > Cad Trainer
Message 5 of 8
Ok For the rest of us that are a little on the slow side, how do you use
that within VBA? Do you use the sendkeys command?
BTW I had opened IE from the command line with that, then I tried to use it
with sendkeys, and experienced my first Blue Screen in a long time.
Probably coinckadink but made me decide to ask more
Kent Keller
Strobe Data Inc.
www.strobedata.com
To every complex problem there is an easy answer;
and it is wrong!
"Frank Oquendo" wrote in message
news:874pv7$d6j34@adesknews2.autodesk.com...
> Glad to help.
Message 6 of 8
Try this. Be sure to add a reference to the Microsoft Internet Controls to
your project first:
Public Function LaunchBrowser(sURL As String)
Dim obj As InternetExplorer
Set obj = New InternetExplorer
obj.Navigate sURL
obj.Visible = True
End Function
"Kent Keller" wrote in message
news:874san$d5d34@adesknews2.autodesk.com...
it
> Kent Keller
> Strobe Data Inc.
> www.strobedata.com
> and it is wrong!
> > Glad to help.
Message 7 of 8
Frank
Meant to post this here, instead of buzzing your mailbox.
What if you don't know what browser a person will have? Is there a way
around that in VBA?
Kent Keller
Strobe Data Inc.
www.strobedata.com
and it is wrong!
news:874uj3$d6533@adesknews2.autodesk.com...
> your project first:
> obj.Navigate sURL
> obj.Visible = True
> End Function
use
> it
> > Kent Keller
> > Strobe Data Inc.
> > www.strobedata.com
> > and it is wrong!
> > > Glad to help.
Message 8 of 8
This will call the default browser.
Option Explicit
Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal
hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal
lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long)
As Long
Public Const SW_SHOWNORMAL = 1
Sub main()
Dim result As Long
result = ShellExecute(0, "open", "http://visual-engineering.com/", 0&, 0&,
SW_SHOWNORMAL)
Ens Sub
Alexander Medwedew
Kent Keller wrote in message <875411$fdh9@adesknews2.autodesk.com>...
>around that in VBA?
