Escape in SendCommand
Message 1 of 8
I am trying to send a command from an ActiveX control, and I would like it
to work much the way the toolbar buttons do. For example if you want to
program a button to draw a line inside of AutoCAD you simply program the
button with "^C^C _line" This doesn't seem to work from within VB and my
ActiveX control. Anyone have any thoughts? BTW, I really do need to use the
sendcommand, I know that there are other ways to draw a line from VB.
Rob
Replies (7)
Message 2 of 8
^C represents ASCII 03 (Cancel).
Send a Chr(3) and see if that works.
> Thanks,
> Rob
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 8
Chr(3) is ESCAPE
Get free software and more at http://www2.stonemedia.com/~franko
"Rob Brown" wrote in message
news:8ECCAD872rbrownautometriccom@167.216.128.159...
the
> Thanks,
> Rob
Message 4 of 8
Sorry Rob. I didn't see the last part of your post. No, you don't have to
use SendCommand to draw line from ActiveX. Just use the AddLine method of
the ModelSpace object.
"Frank Oquendo" wrote in message
news:874veg$fcv1@adesknews2.autodesk.com...
> Chr(3) is ESCAPE
it
> the
> > Thanks,
> > Rob
Message 5 of 8
Frank Oquendo wrote:
> Chr(3) is ESCAPE
Wrong again.
Chr(03) is ^C (look it up on any ASCII table), and Chr(3)
is what AutoCAD receives when ^C appears in a menu macro.
ESCape is Chr(27)
Message 6 of 8
No Frank,
You were right with the first response, I DON"T WANT TO use the addline
method. What I have done is added some icons to the dockable container, and
want them to work as they do in AutoCAD normally I thought that I tried the
CHR(3) but with the day I've had I may have mistyped.
Thanks for the response,
Rob
franko@nospam.stonemedia.com (Frank Oquendo) wrote in
<874vr1$fdi4@adesknews2.autodesk.com>:
>to use SendCommand to draw line from ActiveX. Just use the AddLine
>method of the ModelSpace object.
>> Chr(3) is ESCAPE
>> > like
>it
>> > want to program a button to draw a line inside of AutoCAD you simply
>> > program the button with "^C^C _line" This doesn't seem to work from
>> > within VB and my ActiveX control. Anyone have any thoughts? BTW, I
>> the
>> > VB.
>> > Thanks,
>> > Rob
Message 7 of 8
So did Chr(3) work for you?
news:8ECCA9F4Brbrownautometriccom@167.216.128.159...
> No Frank,
and
the
> Rob
> >> Chr(3) is ESCAPE
> >> > like
> >it
> >> the
> >> > VB.
> >> > Thanks,
> >> > Rob
Message 8 of 8
Thanks for the responses, I got it to work, I didn't think about doing it
that way, it makes a lot of sense. I wrote this neat little tiny app that
sends me the ASCII code of any key that you hit.
Tony, you're right, but for my purposes either string works...
Rob
tony.tanzillo@worldnet.att.net (Tony Tanzillo) wrote in <3896031C.4DFDCA28
@worldnet.att.net>:
>> Chr(3) is ESCAPE
>Wrong again.
>ESCape is Chr(27)
