McadApplication
McadApplication
Message 1 of 9
McadApplication
I'm starting to play around with the mcad object model and I can't even get
off the ground.
VBA keeps stopping with "Problem in loading application"
heres the line of code that it stops on:
Set mapp = ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
Any help would be great.
Michael Browne
Replies (8)
Message 2 of 9
Which version of MDT are you working with, Michael?
Get free software and more at http://www2.stonemedia.com/~franko
"Michael Browne" wrote in message
news:874upt$fdb1@adesknews2.autodesk.com...
get
> off the ground.
> Michael Browne
Message 3 of 9
Are you running the VBA code in an MDT session?
news:8750qc$fct4@adesknews2.autodesk.com...
> MDT4
> I've selected the references:
> BRepAuto
> GeAuto
> McadAuto
> SymBBAuto
> everything shows up in the object browser
> I hope you have some idea.
> Frank Oquendo wrote in message <874vft$f992@adesknews2.autodesk.com>...
> >get
> >> off the ground.
> >> Set mapp =
> >> Michael Browne
Message 4 of 9
MDT4
BRepAuto
GeAuto
McadAuto
SymBBAuto
>get
>> off the ground.
>> Michael Browne
Message 5 of 9
Sounds like you might be missing some registry entries. Run the SETUP from
your CD and choose "Reset Registry"
news:875189$fed5@adesknews2.autodesk.com...
> Yes.
> I've copied some of the sample code from the help file but nothing loads
> Sub GetAttributes()
> Dim mapp As McadApplication
> Dim util As McadUtility
> Set mapp =
> Set util = mapp.ActiveDocument.Utility
> Dim pick As McadPick
> Set pick = util.pick("Select geometry", mcGeometry)
> Dim geom As IMcadGeometry
> Set geom = util.GetGeometryFromPick(mcGeometry, False, pick)
> Dim atts As McadAttributes
> Set atts = geom.GetAttributes
> Dim att As McadAttribute
> For Each att In atts
> Debug.Print "Attribute: " & att.ClassName
> Dim count As Long
> count = 0
> While count < att.FieldCount
> Debug.Print vbTab & "Field: " & att.FieldName(count) & vbTab &
> "type = " & att.FieldType(count)
> Dim val As Variant
> val = att.FieldValue(count)
> If IsArray(val) Then
> Dim item As Variant
> For Each item In val
> Debug.Print vbTab & vbTab & item
> Next
> Else
> Debug.Print vbTab & vbTab & val
> End If
> count = count + 1
> Wend
> Next
> End Sub
Message 6 of 9
Yes.
Sub GetAttributes()
Set mapp =
Dim count As Long
count = 0
Dim val As Variant
Dim item As Variant
Next
Else
count = count + 1
Wend
Next
End Sub
Message 7 of 9
I think I found it!!
I ran the MDT SP2 which must have rewriten some entries. It did work prior.
So I re-ran the McadAutoReg.exe to re-register the McadAuto stuff and it
works know.
I have one last question for you Frank;
How do I know what to put with in the GetInterfaceObject("????.????")
Thanks for your help Frank,
Michael Browne
Frank Oquendo wrote in message <8751b9$fcu11@adesknews2.autodesk.com>...
>> Yes.
>> Sub GetAttributes()
>> Set mapp =
>> Dim count As Long
>> count = 0
>> Dim val As Variant
>> Dim item As Variant
>> Next
>> Else
>> End If
>> count = count + 1
>> Wend
>> Next
>> End Sub
Message 8 of 9
Here are the ProgIDs for the four top-level objects in the MDT object model.
If there's an error, I'm sure 3T will be along shortly to point it out.
MCAD.Application
SymBBAuto.McadSymbolManager
Brep.Application
Ge.Application
news:8751um$fcv8@adesknews2.autodesk.com...
prior.
> works know.
> Michael Browne
from
> >> Yes.
loads
> >> Sub GetAttributes()
> >> Set mapp =
> >> Dim count As Long
> >> count = 0
vbTab
> >> Dim val As Variant
> >> Dim item As Variant
> >> Next
> >> Else
> >> End If
> >> count = count + 1
> >> Wend
> >> Next
> >> End Sub
Message 9 of 9
Thanks for your help Frank. As always, much appreciated.
Frank Oquendo wrote in message <8752jd$fcu15@adesknews2.autodesk.com>...
model.
>MCAD.Application
>Brep.Application
>Ge.Application
>prior.
>> works know.
>> Michael Browne
>from
>> >> Yes.
>loads
>> >> Sub GetAttributes()
>> >> Set mapp =
>> >> Dim count As Long
>> >> count = 0
>vbTab
>> >> Dim val As Variant
>> >> Dim item As Variant
>> >> Next
>> >> Else
>> >> End If
>> >> count = count + 1
>> >> Wend
>> >> Next
>> >> End Sub
