How to open dwg one by one use delphi 5 and A2K?
Message 1 of 13
I'm a new comer in delphi. I need open a lot of big dwg file
one by one.In my program I can open one dwg file but I can not
open them one by one. I get a error massage "the call be refused"
(Sorry. Because I used japanese version I can't give the exactly
error message). Is any one can help me or recommend some examples(VB or
delphi) .
By the way, how can I open some dwg files in same time with delphi and
A2K?
thank you!
This is my program.
function MyOpen(DWGFile: String): Boolean;
var
AcadObj: Variant;
acadDoc: Variant;
LayerColl, aLayer, ActLayerObj: Variant;
LayerName, ActiveLayerName : String;
begin
try
AcadObj := GetActiveOleObject('AutoCAD.Application');
except
try
AcadObj := CreateOleObject('AutoCAD.Application');
except
Exit;
end;
end;
AcadObj.Visible := True;
Acadobj.Documents.open(DWGFile);
acadDoc := AcadObj.ActiveDocument;
// acadDoc.Open(DWGFile);
LayerColl := acadDoc.Layers;
ActLayerObj := acadDoc.ActiveLayer;
ActiveLayerName := ActLayerObj.Name;
//to freeze every layer without '0'
for cnt := 0 to LayerColl.Count - 1 do
begin
aLayer := LayerColl.Item(cnt);
LayerName := aLayer.Name;
if ( ActiveLayerName <> '0') and ( LayerName = '0') then
acadDoc.ActiveLayer := aLayer;
if LayerName <> '0' then
aLayer.Freeze := True;
end;
// other process
end;
// for test
procedure TForm1.Button1Click(Sender: TObject);
begin
MyOpen('01.DWG');
MyOpen('02.DWG');
MyOpen('03.DWG');
end;
Replies (12)
Message 2 of 13
Can you tell me on what line of your code you get the error?
> delphi) .
> A2K?
> thank you!
> This is my program.
> var
> AcadObj: Variant;
> acadDoc: Variant;
> begin
> try
> except
> try
> except
> Exit;
> end;
> end;
> begin
> end;
> // other process
> end;
> // for test
> begin
> MyOpen('01.DWG');
> MyOpen('02.DWG');
> MyOpen('03.DWG');
> end;
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 13
Thank you !
My program is stop on
My dwg size is gigger than 1500k.
ZhouZuo
> > delphi) .
> > A2K?
> > thank you!
> > This is my program.
> > var
> > AcadObj: Variant;
> > acadDoc: Variant;
> > begin
> > try
> > except
> > try
> > except
> > Exit;
> > end;
> > end;
> > begin
> > end;
> > // other process
> > end;
> > // for test
> > begin
> > MyOpen('01.DWG');
> > MyOpen('02.DWG');
> > MyOpen('03.DWG');
> > end;
Message 4 of 13
The error occurs because the Layer property of an object
is not a Layer object, it is a string that contains the name
of the object's layer.
You only have to change the line of code to this:
LayerName := aLayer;
zhouzuo wrote:
> Thank you !
Message 5 of 13
Thank you for the help!
I changed my program but it does not work.The error is
"Variant be changed into wrong type"(in japanese) on line
The problem is happening when I used the big dwg. Are there
some mothod let me to wait for one dwg be process over? Or there are
something wrong in save dwg. I use
acadDoc.save;
I so sorry to trbouble you.
> zhouzuo wrote:
> > Thank you !
Message 6 of 13
Sorry, I thought you were processing a collection
of AutoCAD entities, not layers. In that case,
disregard the last instructions, as it is wrong.
Try replacing the line "LayerName := aLayer.Name:"
with the following code, and tell me what you see
displayed in the message box:
try
except On e: OleSysError do
ShowMessage(Format("ErrorCode = %d", [e.ErrorCode]));
end;
> acadDoc.save;
> > zhouzuo wrote:
> > > Thank you !
Message 7 of 13
The error code is
"ErrorCode = -2147418111 "
Some time the programe stop before the line
but the error code is same.
By the way I test the program in "SDI" mode.
ZhouZuo
> try
> end;
> > acadDoc.save;
> > > zhouzuo wrote:
> > > > Thank you !
Message 8 of 13
Try modifying your code like so:
var
AcadObj: Variant;
acadDoc: Variant;
begin
try
except
try
except
Exit;
end;
end;
While (True) do
begin
try
except
Application.ProcessMessages;
continue;
end;
break;
end;
> The error code is
> ZhouZuo
> > try
> > end;
> > > acadDoc.save;
> > > > zhouzuo wrote:
> > > > > Thank you !
Message 9 of 13
Thank you Tony!
I modifed my program but it still have same problem.
I found the While loop do not work. I put a break point
on "Application.ProcessMessages" but is do not stop whatever
it wrong or it ok.
If you put the break point on
"acadDoc := AcadObj.ActiveDocument;"
the program will doing very well.
Can you tell me where I can found meaning of error code?
I'm so sorry for take you so mach time.
> var
> AcadObj: Variant;
> acadDoc: Variant;
> begin
> try
> except
> try
> except
> Exit;
> end;
> end;
> While (True) do
> begin
> try
> except
> continue;
> end;
> break;
> end;
> > The error code is
> > ZhouZuo
> > > try
> > > end;
> > > > acadDoc.save;
> > > > > zhouzuo wrote:
> > > > > > Thank you !
Message 10 of 13
The error code is telling you that AutoCAD is not available
to service Automation calls. This may be because the Open()
method is not waiting until it is before it returns, and
your next attempt to call into AutoCAD is failing because
AutoCAD is not quiescent.
After you call the Open() method, try inserting the following:
While(not AcadObj.GetAcadState.IsQuiescent) do
zhouzuo wrote:
> Thank you Tony!
> it wrong or it ok.
> > var
> > AcadObj: Variant;
> > acadDoc: Variant;
> > begin
> > try
> > except
> > try
> > except
> > Exit;
> > end;
> > end;
> > While (True) do
> > begin
> > try
> > except
> > continue;
> > end;
> > break;
> > end;
> > > The error code is
> > > ZhouZuo
> > > > try
> > > > end;
> > > > > acadDoc.save;
> > > > > > zhouzuo wrote:
> > > > > > > Thank you !
Message 11 of 13
Thanks for new suggestion!
I changed my code as you told me but it does not
work . Maybe the problem is not in AcadObj (application),
it is in acadDoc (ActiveDocument). Maybe I have to use
different method to open DWG in SDI mode.
Now I changed my A2K into MDI mode.It work now!
Would you tell me how can I not display the error message when "except" happen.
for example
except
(in VB,can use Err.clear)
Thanks.
Here is my code now.Just for MDI.
var
AcadObj: Variant;
acadDoc: Variant;
F: TextFile;
S: string;
cnt: integer;
//for judge of SDI or MDI
sysVarName :String;
varData : Variant;
begin
try
except
try
except
Exit;
end;
end;
Acadobj.Documents.close;
While (True) do
begin
try
except
continue;
end;
break;
end;
sysVarName := 'SDI';
varData := AcadDoc.GetVariable(sysVarName);//no use
begin
$B!!(BLayerName := aLayer.Name;
end;
if varData = 1 then
acadDoc.save
else
Begin
if AcadDoc.Saved = TRUE then
AcadDoc.save;
AcadDoc.close;
end;
end;
Message 12 of 13
If you use try...except...end to catch errors, then they
should not appear, unless there is a second error that
occurs in the code appearing between except and end.
> for example
> except
> Thanks.
> var
> AcadObj: Variant;
> acadDoc: Variant;
> F: TextFile;
> S: string;
> cnt: integer;
> sysVarName :String;
> varData : Variant;
> begin
> try
> except
> try
> except
> Exit;
> end;
> end;
> While (True) do
> begin
> try
> except
> continue;
> end;
> break;
> end;
> begin
> end;
> if varData = 1 then
> acadDoc.save
> else
> Begin
> AcadDoc.save;
> AcadDoc.close;
> end;
> end;
Message 13 of 13
Thank you for all the help!
I'll let mo program allways run under MDI mode.
Zhou Zuo
> > for example
> > except
> > Thanks.
> > var
> > AcadObj: Variant;
> > acadDoc: Variant;
> > F: TextFile;
> > S: string;
> > cnt: integer;
> > sysVarName :String;
> > varData : Variant;
> > begin
> > try
> > except
> > try
> > except
> > Exit;
> > end;
> > end;
> > While (True) do
> > begin
> > try
> > except
> > continue;
> > end;
> > break;
> > end;
> > begin
> > end;
> > if varData = 1 then
> > acadDoc.save
> > else
> > Begin
> > AcadDoc.save;
> > AcadDoc.close;
> > end;
> > end;
